All 2st fixed my subframe :)
Discussion in '2 Stroke' started by Anthony_1978, Jan 9, 2011.
  1. Anthony_1978 Husqvarna
    Melbourne
    i was sad that my side panels needed to be zip tied to the sub frame
    after the OEM nut-serts just kept spinning in the sub-frame... so i fixed it
    here's how :cheers:
    [YOUTUBE]i2i5TW6sFHQ[/YOUTUBE]
  2. Pedec Husqvarna
    Sask.Canada
    I had the same thing happen on my 2008 cr 125. I could not get my side panel off. I cut a small hole on the inside of sub frame to hold nut to get screw out.
  3. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    I need to do this too.
    Anthony,
    was the new nut-sert the exact same size as the original?
    The hole in my subframe is not perfectly round anymore, so I think I'll have to drill it and use the next larger size.
  4. Anthony_1978 Husqvarna
    Melbourne
    Hey PC,
    i just went to the local bearing wholesale store and brought a few different sizes i'm pretty sure i ended up using 8mm stainless steel nutserts (6mm thread) when tightened up as shown, the inside end expands and will lock into the subframe. don't drill anything till you try a few different size nutserts:thumbsup:
    this is an example of the nutserts
    http://cgi.ebay.com/ebaymotors/AIRC...89665696QQptZMotorsQ5fAviationQ5fPartsQ5fGear
    this is a special tool for nutserts (not really necessary)
    http://cgi.ebay.com/ebaymotors/Nuts...Z400138771103QQptZMotorsQ5fAutomotiveQ5fTools
    good luck mate
  5. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Thanks for the info!
    Cheers :cheers:
  6. Anthony_1978 Husqvarna
    Melbourne
    no worries i love this site, its helped me heaps too :thumbsup:
