How to remove throttle stop & enable the AP on a 2006 TE
Discussion in '4 Stroke' started by Coffee, Dec 28, 2008.
  1. Coffee CH Owner
  2. Coffee CH Owner
    How to remove throttle stop & enable the AP on a 2006 TE - discussion thread
    Any input?
  3. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
  4. Coffee CH Owner
    Links to other places are fine.
    Putting up info from your hard disc is fine.
    Copying stuff from other forums - not fine.
    Thing is this is, and will always be, a sensitive topic. In my post on the thread on TT I posted this:
    Dunno what the answer is... hey we can do anything we want on CH right? I could make it so people need to be logged in to see this section.
    That ok with everyone?
  5. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Seems ok to me. Just want others to be aided by our work.
  6. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    Was this an '08 610? I seem to get conflicting information on the 08's as some folks report that there is no throttle stop.
  7. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Oops, should have been more specific for everyone here. It's on an 08 TE510, which is the same as the 08 TE/SM 250/450/510's. Don't know about 610's as it's a different engine. You're right, not everyone had a throttle stop installed when purchased from the dealer. Mine did, a few of my friends' 450/510's did not and were purchased from same dealer. I don't know the rhyme or reason for it. Perhaps some of them had dealer install power up kit at purchase time and dealer removed throttle stop along with the installation? I installed my kit personally. :excuseme:
  8. Coffee CH Owner
    Making a copy of this thread...
    Tech Ref --->>> 4st
  9. 04asphalt Husqvarna
    SW Michigan
    so the 08 te610 has no stop? seems like from closed to full open is very "short"
  10. dave lindsey Husqvarna
    San Antonio, TX
    None
    2015 300 XCW/2012 CRF230F
  11. Ron West Husqvarna
    Capistrano Beach, Ca
    2007 TE250
    Honda NX250, & 2000 Africa Twin
  12. Coffee CH Owner
    Yeah.. I would think that you could use a bit more power by now :)
    www.sudco.com
    "Needle Set Screw" - Sudco part # 021-727, Keihin #1421-802-2000
    This is what goes where the throttle stop was (in the top of the slide).
    Or call any fine Husqvarna dealer... that is where I got mine, but that was many years ago.
  13. Ron West Husqvarna
    2007 TE250
  14. Ron West Husqvarna
    2007 TE250
    Hey one more quick question. Since I purchased my bike used (even though it only had 100miles) I'm not sure what's been done. My throttle turns a bit less then 1/4 turn. Think that factory stop is still in there?
  15. Coffee CH Owner
    Pretty drastic difference with and without throttle stop - 1/8 turn instead of 1/4.
    Could still have the throttle stop in, not sure from what you typed. Pretty simple to find out, loosen the band clamp, rotate the carb a bit, take the top off.
    It is possible that the previous owner simply cut the top off the throttle stop and did not put in the actual factory replacement, many people did that.
