Vintage Race Mods /Tech Tips and Media ( magazine articles)
Discussion in 'Vintage Tech Ref and Parts' started by HuskyT, Apr 14, 2009.
  1. HuskyT Moderator
    Corona, California
    Please post Race Mods/Tech Tips and Media ( magazine articles) on Vintage Husqvarna in this thread.
    Let's try and keep this thread uncluttered with less social chat and let it develop as a good resource that guys can quickly look through years from now.
    Please post up with a title that includes the bike size/model and describes clearly the article or race mod or tech tip that is being discussed
    For example : 1980 CR 390 Swingarm Mod
    Thanks to M357.5 for the concept of this thread !:thumbsup:
  2. HuskyT Moderator
    Corona, California
    Mxa motocross action 1975 cr125 and cr360
    Circa 1975 CR 125 and CR 360 MotoCross Action Magazine Feature Articles
    Article as follows made available by LeftCoast Left Kicker:thumbsup::cheers:
    T
  3. HuskyT Moderator
    Corona, California
    GoKeefe Procircuit CR470
    I wish I could find on of these Procircuit rear fenders....
    Courtesy of LeftCoast Left Kicker
    T
  4. HuskyT Moderator
    Corona, California
    Andy Jefferson (old School)
    Cool that I have now rode at Glen Helen the same time as Andy in the February'09 and March'09 SRA Gp's at Glen Helen on current Husqvarna's
    Courtesy of Left Coast Left Kicker!!
    T
  5. HuskyT Moderator
    Corona, California
    Replacement Sprag Clutches for 1976 1977 360 Autos
    The following information is for replacement of Sprag clutches on 360 Auto's. Whomever Peter may be .... great Information:thumbsup::applause:
    Information courtesy of LeftCoastLeftKicker
    Information as follows:
    *REPLACEMENT SPRAG CLUTCHES (Freewheeling Device)*FOR THE 1976-77 360 AUTOMATIC
    *After restoring my 1976*360 Automatic from a basket case,*I had the Sprag Clutch fail on the main crankshaft. It appears that these clutches are not longer available or very hard to come by*from most Husky Dealers. I have found that an equivalent part is*still manufactured by a company in Germany with the correct sizes to suit the 360 Auto (as I have a*360 I don't know if the same part*numbers are suitable*for the later 390cc and up Autos), but they make a lot of sizes so you should find one to suit from shaft diameter 14mm to 80mm.
    *The*1976 & 77 model 360 Automatics*use five Sprag Clutches (free wheeling devices),*one on the main crankshaft and a further four in the automatic gearbox transmission which are real easy to change, but remember which direction the dogs in the clutches are facing before you remove them from the shafts,*so you get the gears to lock up in the right direction or you will have a gearbox of four neutrals and can't be pushed forwards.
    For the crankshaft you must use the correct puller to remove the Main*Centrifugal*Clutch and Housing to access the clutch and*replace the Sprag Clutch, again note the direction of the dogs before removing and replacing the faulty Sprag Clutch.
    THE SIZES AND*GMN*PART NUMBERS FOR THE*1976 & 77 AUTOMATIC ARE AS FOLLOWS;**
    ************"THE CRANKSHAFT REQUIRES ONE FREEWHEEL CLUTCH INSERT".
    Crankshaft: 1 x*GMN (freewheel-clutch insert) part number FE433Z (SIZE *ID 25mm x*OD 33mm x 12mm wide).
    ************ "THE GEARBOX REQUIRES FOUR FREEWHEEL CLUTCH INSERTS".
    Gearbox:*2 x GMN part number FE438Z (SIZE*ID 30mm x OD 38mm x 12mm wide).
    ************* 1 x GMN part number FE458Z (SIZE ID 50mm x OD 58mm*x 12mm wide).
    **************1 x GMN part number FE478Z (SIZE ID 70mm x OD 78mm x 12mm wide).*
    *The*Company that makes the Clutches is GMN in Germany and they have a web site that has all the sizes there if these are different to*the later model Automatics ( 390cc, 430cc, 500cc ).*
    Your local Bearing Agent should be able to get them in for you fairly easily. The web site is *www.gmn.de/(ex)/e/**GMN-PAUL MULLER GMBH. If you enquire*they will readily let you know who your local importer is for your country.
    Peter.
    T
  6. HuskyT Moderator
    Corona, California
    1980 ProCircuit CR 125 Husky Hop Up from MXA magazine
    1980 Procircuit CR125 Husky Hop up from January 1980 MXA Moto Cross Action Magazine
    Courtesy of Left Coast Left Kicker!:thumbsup:
  7. HuskyT Moderator
    Corona, California
    Cycle World 1976 360 Auto Article
    Article from 1976 Cycle World on 360 Auto's
    T
  8. HuskyT Moderator
    Corona, California
    Cycle Guide 1983 XR350 Honda VS. Husky 430WR by Ron Lawson
    Cycle Guide 1983 comparison article
    T
  9. HuskyT Moderator
    Corona, California
    1984 Team Husqvarna CR 250 Tuning Tips
    1984 Team Husqvarna CR250 Tuning Tips
    TEAM Husqvarna
    Tuning of 250 CR 84
    Cylinder: Smooth all edges between aluminum and steel liner. Note! Only smooth the aluminum. Do not change the port times in the liner.
    Intake: Make sure the top of the port is according to figure 1, with a straight top, about 10 mm wide.
    Transfer ports: Make the ports square according to figure 1. Make sure the top of the transfer ports are 49.5 mm from the top of the liner and that all ports are at the same height (lined up).
    Remove material in the transfer ports as per figure 3.
    Remember: Adjust the carburetor
    Do not let the engine “ping”
    Smooth the edges of the liner
    Warranties do not apply. The result of the tuning is not guaranteed.
    T
  10. HuskyT Moderator
    Corona, California
    Popular Cycling Cr125 husky hop up
    CR125 HUSKY HOP UP ... YEAR ??? 75 / 76 ?
    Nils Arne Nilsson Feature
    Courtesy of LeftCoastLeftKicker!:thumbsup:
    T
