Radiator guards/braces
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by BCVisin, Feb 22, 2010.
Radiator Braces?
Yes, definately run with them. 26 vote(s) 78.8%
No, you are better off without them. 1 vote(s) 3.0%
I am on the fence. 6 vote(s) 18.2%
Multiple votes are allowed.
  1. BCVisin Husqvarna
    Temecula, CA
    So I have some radiator braces. Im deciding right now weather to put them on, or leave them off. Im not to concerned with air flow, as I run fast enough speeds in the desert that I don't think the temp will matter that much, but I want your opinion. Do you think that It's better to run with them or without them. I have heard both sides of the argument:
    1. It's that it's better to crash with them because they brace your radiators and prevent them from getting bent/damaged because the force is on the brace and transferred to the frame.
    2. It's better to run without them because when you crash, the braces cause more bad than good and crack the aluminum. If you crash without the braces, the radiators just bend and crush, but won't fracture, causing leakage, and stranding you on the trail.
    So what do you all think? The braces I have have have supports in the back, and wrap all the way around. Give me your opinion.
    -Blake
  2. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    I've never ran braces. Never had a crash bad enough to crush or damage a rad. (On a dirtbike)
    I've had branches a sticks etc. kicked up and poke holes in my rads.:banghead:
    Therefore I just run guards only.
    :cheers:
  3. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    Dunno about track or racing. But bush riding is essential.
  4. Colo moto CH Sponsor
    La Jara, Colorado
    7602racing.com
    Run them. Unless you like pushing your bike through the desert. The first two offroad races I entered I dnf'd because of a torn up radiator that would have survived if I had a brace on it. So now I'm a believer.
  5. rancher1 Husqvarna
    WA
    what he said :cheers:
  6. Thirsty2454 Husqvarna
    Australia
    They'll save your rads more times than hurt them. Its a no brainer mate. Throw them on.:thumbsup:
