'01 te570 high altitude...tuff starter
Discussion in 'Older Single cams' started by 2strokefixer, Sep 9, 2014.
  1. 2strokefixer Husqvarna
    Lake Tahoe CA
    '86 400 xc, '01 te570, '99 wr250
    I recently picked up an '01 te570... she was serviced before the guy I bought it off of let her sit for awhile. She'll start and go, no prob. I live at 6200ft, shes tricky to start cold... a lot of kicking. Once she's running she charges! I get to the top of my local trail (at least 7000ft above sea level) good luck restarting unless you point down hill put it in 3rd and pop it. The seller said it has a "new" carb, and yes it looks brand spanking new... the only prob is that it doesn't look like the carb in the workshop manual. It sounds like a carb adjustment to me but is just fiddling w/the screws gonna give enough adjustment or should I go ahead and drop the needle down a notch? Thanks in advance...
    Dave
    ps: also can anybody walk me through the airbox mod that ive heard so much about
  2. DaveM Husqvarna
    Adelaide, Australia
    2001 TE 570
    Motorised Bicycle
    Hi 2strokefixer,
    The air box side cover should have round circles imprinted on the inside, you need to cut them out, then glue some mesh
    on the back to stop big stuff going through the holes.
    With carbs and jetting you really need to know what you are doing it is not easy, have you done plug chops before? Can you
    set the mixture screw?
    If not, might be time to pay someone to do it properly.
    Cheers, Dave.
  3. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    What kind of Carb is in your bike?
    Dellorto?
    Mikuni?
    Keihin?
  4. 2strokefixer Husqvarna
    Lake Tahoe CA
    It's a dellorto. As for carb adjustment I feel confidant enough to do them. I've done a few rebuilds here and there just always on 2strokes. Today she started right up, cycled the motor over a couple times w/ a handfull of soft kicks ten choke down and two mule kicks later...fired up. The choke feels like its got a spring in it that's too tight not allowing it to stay in the open position.
  5. 2strokefixer Husqvarna
    Lake Tahoe CA
    I'm not going to go as deep a plug chops. As for adjusting the mixture screw, tomorrow morn I'm going to warm her up hook up the tach turn the idle screw till she's running bout 1200rpm the adjust the mixture screw a bit see where I'm at from there then let the idle screw back down... Just going to follow whats in the shop manual. Then some grinds and I are headed to bucks lake via the rubicon.
  6. Norman Foley Husqvarna
    Choke lever should flip all the way up, to almost vertical and lock. Kicking slowly and deliberately, works better than a fast mule kick..... If you stall it, hold the manual decomp lever open and kick through 10 times quickly, then start as usual and it will fire right up.
  7. 2strokefixer Husqvarna
    Lake Tahoe CA
    The choke lever goes to the "almost vertical" position it just doesn't lock... It springs back as if under too much tension.
  8. Miezie666 Husqvarna
    Germany
    got the same problem, always have to fiddle with the choke lever- lucky me i only need this once a day ;-)
