250-500cc 02 CR250 UPDATE OR MOD
Discussion in '2 Stroke' started by actm7, Mar 15, 2014.
  1. actm7 Husqvarna
    CR125
    I have a 02 cr 250 with pro circut pipe that is in good shape , trying to make up mind what to do thinking about tradeing it in on newer husky or gas gas or brand new . but as a B/C level mx rider an some woods rideing. Is there any gain to a new two stoke? or just mod mine some?
  2. nonamerider Husqvarna
    Oklahoma
    there are gains but the 02 cr best husky made .i have redone 7 02 there are mods that greatly enhance the bike alot of little things husky should of done. i have tested and raced these 2 strokes for years.even rode support for cagiva back in the day.the bikes will perform and last forever if setup correctly
    shrubitup likes this.
  3. actm7 Husqvarna
    CR125
    What would you suggest for changes to bike? What is hp of 02 compared to newer bikes?
  4. nonamerider Husqvarna
    Oklahoma
    hp 44.susp mods gearing 13 50 /carb stock or after market where do you live or ride.adj clutch inner to 3/5mm play.motor use .03 base gasket that will bring squish .70.low end power run stock siencer mid to top run fmf. procircut low end shorty.jd ing.bestpipe tested doma hard to get.spes and dep next best.thesemods are simple effective.ihave more specific mods but these mods wil bring the 02 to life.carb is real imporant but need to know what you have and where. thanks sorry for run on getting ready for supercross and riding.anything specific iwill get more detailed.
  5. actm7 Husqvarna
    CR125
    I put complete pro circuit exhaust on it has stock carb thinking about lectron carb like I run on my 165 . I live in sd so most of rideing is more open. I will install diff base gasket. Thanks for help no name I think I spoke with you once on phone when I was thinking of selling this bike
  6. nonamerider Husqvarna
    Oklahoma
    yes sir..stock carb use 61 needle 4 slide 32.5 pilot 370 390 main when warm . amsoil int 44/1. good luck.
