125-200cc 04 Bodywork swap
Discussion in '2 Stroke' started by robj, Oct 7, 2020.
  1. robj Husqvarna
    NZ
    2001 CR125
    KX/KDX200 hybrid
    Hey bit of a blast from the past, but do you know if the 04 CR125 tank, seat and plastics would bolt straight onto an 08 CR125? I have found a low hour 08 and would like to convert to the ergos of the 00-04. Thanks
  2. robj Husqvarna
    NZ
    2001 CR125
    KX/KDX200 hybrid
    Ok, I'll take a punt on it.
  3. rancher1 Husqvarna
    WA
    People switched the 05 to 08 plastic to the 04 models so it should work the other direction.
    robj likes this.
  4. Sonnie Mee Husqvarna
    England
    Team Motorex Husqvarna CR125
    The tank side panels and rad shrouds should fit but I am not sure if the rear fender or side plates will fit I think the sub frame is slightly different you might have to change the rear subframe, seat, rear fender and side panels
    robj likes this.
