the other day i started up my bike and none of the number on the gage or the lights around the gage lit up, the back light come on but i have a blank screen and no indicatior lights for blinkers, headlight, highbeam, and gas. I was thinking maybe a fuse but i figured the whole gage would have gone out if it was a fuse. If anyone has any imput a little help would be greatly appreciated. Thanks
I have no idea how it's wired on your bike but is there any chance it could be a loose plug at the back of the cluster? Assuming there is a plug it would be worth disconnecting it, cleaning the contacts on both parts, and refitting it to see if that makes any difference. Given how many different things aren't working you're probably looking at a common cause such as failed power or earth to the cluster, which could be a fuse if there is one which just feeds the cluster (assuming everything else is ok). Let's hope it's something like that rather than the cluster itself having failed.
I would do the classic re-boot, dis-connect battery for a few minutes, maybe 20, then re-connect and see what you have. That's after checking wires etc. Probably has a little lithium button battery to hold memory too. That may be an issue too.
