'06 SM610 won't turn over
Discussion in '610/630' started by rt9bil, Dec 29, 2010.
  1. rt9bil Husqvarna
    PA
    Guys, its been about 2 months since I rode my '06 sm610 due to breaking my collar bone. I went out today to start it up and it just won't turn over. I think I checked everything. I replaced the gas, checked the plug, replaced oil and filter. Battery is showing good voltage. I turn the key, everthing works as normal, the bike cranks good, it just doesn't fir up. Maybe alittle starter fluid in the carb? I'm lost.
  2. Coffee CH Owner
    I'd whack the throttle a few times while cranking so the accelerator pump squirts fuel in.
    If you did already try that, I'm not sure what might be wrong. My guess would be a plugged pilot jet, hence my suggestion to whack the throttle, so there would be fuel even with a plugged pilot jet.
  3. MotoXotica Husqvarna
    Vacaville
    possibly the carb has a plugged pilot jet.dan
