This is probably gonna be my biggest noob question in regards to the Husky. Previous owner hacked up some factory wiring which I had no trouble fixing but I do have a question about the fuse box. The schematics show only a 15A in the block but there is a space for another fuse which is not in there currently...I see there is supposed to be a 10A inline running to the fan but I can't find that and wondered if the space in the block is for that...can anyone confirm (I bet it's for a spare but not sure)? I guessing it's not because I confirmed with my meter that the 15A is tied into the fan circuit so I'm a bit confused.
I wish I could help, but do not have a 2006 TE610.. I believe there was a space for a spare fuse on my 2006 TE250 though, maybe?
Thanks Coffee...it's just weird because everything works on the bike, but the P/O told me he hard wired a switch in the fan circuit because the coolant sensor went bad. I see in research this was a known issue, no biggie...but it bothers me I can't find the 10A fuse the factory schematic shows...wondering now if it may have been inline since I'm missing the plug and of the fans wiring harness. Bahh...either way it's fully ridable and as I understand it the fan is kinda overkill unless you plan to sit and idle for more than 10-15 minutes at a clip.
