125-200cc '06 WR125 Setup
Discussion in '2 Stroke' started by woodsrider, Oct 1, 2013.
  1. woodsrider Husqvarna
    WA
    '16 FE 350
    '18 Alta MXR
    Thought I would start a thread about how my new to me '06 WR125 is getting setup. Nothing ground breaking here, but wanted to share what's going on anyway. First order of business was determining that what I thought was an '05 WR125 turned out to be an '06 WR125.
    Bonus!
    Stopped by my local Husky dealer, Tasky's in Everett, and picked up:
    • 2 Moose airfilters. I saw Kelly mentioned he likes the Moose brand ones with the neoprene lip. They had two in stock hanging on the wall. I snagged them. Bonus!
    • 2 spark plugs.
    • Gear oil.
    • Premix oil - Duomonde Tech full syn, my favorite.
    I was hoping they might have a skid plate in stock, but they did not. I had checked with Kelly previously, he didn't have one. Called Bill's today, nope. Called Steahly Offroad, their website shows they carry them. Nope, they do not have it in stock, he said they get them from Ricochet.
    Called Ricochet, they had it in stock, said regular ground shipping to my area is usually 2 days. Placed the order online today. Just got an order status email, UPS picked it up, its on its way.
    Yeah!
    Next order of business will be:
    • Routine maintenance (oil change, air filter, coolant, bleed brakes, spark plug, check chain tension, check suspension settings).
    • Check jetting (bike seemed to run great going around the block).
    • Check powervalve setting.
    • Check nuts and bolts front to back.
    • Check sprocket sizes.
    • Install bark busters.
    • Install skid plate.
    • Take it for a shake down ride!
    • Sell my KTM 125 SX!
    Current setup is:
    • CR plastics
    • Jetting: unknown
    • FMF Fatty pipe
    • FMF Turbine Core II muffler w/spark arrestor
    • HD tubes, brand unknown
    • Sprockets/gearing: unknown, probably stock
    Future mods/maintenance:
    • Suspension: springs front and back for 205 lb rider. Fork mod Kelly told me about.
    • Check bearings including shock linkage
    • Tall seat?
    • Bar risers?
    • Low pegs?
    • IMS gas tank?
    • APT Smartcarb or Lectron?
    • Radiator guards
    • White or red headlight/number plate
    • Install Stabilizer
    • Install Trail Tech Endurance speedo
    • Graphics?
    • WB 165 kit!
    Now I just have to find the time to get to it. And also find time to prep my KTM for sale and list it.
    Anyway, I'm very excited to set this bike up and get it out for its first trail ride, maybe by this weekend. -Ed
    JRod4928, sabortooth and wallybean like this.
  2. Motosportz CH Sponsor
    Top of your list should be to spring it and sort the fork for you. This will be by far your biggest performance, comfort and fatigue mod. The forks are kinda sucky but can be awesome. The springs are WAY soft for you. Going to be hard to judge the bike until you address this.
    woodsrider and wallybean like this.
  3. woodsrider Husqvarna
    WA
    '16 FE 350
    '18 Alta MXR
    Ha ha...yes, I was just dropping my kid off and was thinking "Suspension! Need to add springs front and back and forks mod to my list."
    I'll edit my list above. Thanks.
  4. DRS Husqvarna
    renton
    wr 165
    500 exc
    nice, i just got finished setting a "13 165 up.
    lectron 36 (stock carb with 165kit it's eats a lot of fuel)
    ims tank
    susp resprung
    flexx bars
    fastway evo3 pegs
    cycra busters
    EE rad guards
    EE sharkfin rear disk guard
    scotts submount damper
    new tires/hd tubes
    repacked/greased wheel, head, and swingarm bearings (a bit dry and it had very little time on when i bought it.)
    enjoy!
    woodsrider likes this.
  5. woodsrider Husqvarna
    WA
    '16 FE 350
    '18 Alta MXR
    Nice!
    And you reminded me of a couple of other things to add to the list. At some point I need to check all the bearings (including rr shock linkage).
    Larger gas tank may be necessary, we'll have to see on that one.
    I'm also very interested in the APT Smartcarb. I know the Lectron has been getting rave reviews but I'm holding out to see how the Smartcarb does once its in production and the real world feedback comes in.
  6. TROFFER88 Husqvarna
    Camas Wa
    I have a 06 wr125 also get the Scorpion skid plate , best one out there for that frame.
  7. woodsrider Husqvarna
    WA
    '16 FE 350
    '18 Alta MXR
    Thanks, but I already have the Ricochet skid plate on order, should be here tomorrow. I've had them on a couple of other bikes and was very happy with them.
    And I'd actually like a plastic one like the Hyde skid plates, but it looks like they don't offer one for the 125. Plus their shipping/customer service left a lot to be desired the one time I did buy from them. I also had a KTM OEM plastic one my '04 250 EXC. Wish I knew a little bit about plastic forming because I really like the plastic skid plates.
    454x likes this.
  8. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    I've run the Moose airfilters and had problems with the rubber seal essentially melting. So I'm going back to the Twinair.
    I have a Moose brand skidplate I ordered from Tasky's that doesn't fit my '09. Free if you want it.
  9. Motosportz CH Sponsor
    wonder if it did not like the air filter oil or somthing. Should be be heat related right? I have run mine for many years and it is holding up well using JP1 oil.
    jmetteer likes this.
  10. woodsrider Husqvarna
    WA
    '16 FE 350
    '18 Alta MXR
    Slo, sent you a PM, interested in the skid plate. Where are you located? Thanks.
  11. woodsrider Husqvarna
    WA
    '16 FE 350
    '18 Alta MXR
    Interesting. Just oiled my new ones up with the PJ1 aeresol, so good to know you haven't had any issues with that brand. I'll keep an eye on it though, which I usually do anyway.
  12. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    Not sure if it was oil related or what, but I had 2 different ones do it. I use No Toil filter oil.
  13. Motosportz CH Sponsor
    Yep Notoil is the problem. It ruined two of my filters, they split at the seam, Notoil knows this and will replace if you bitch to them about it. I run Notoil as well but only use their filters because of this. There are several threads on this site talking about notoil ruining filters. I love the stuff so I bought their filters and no more problems. How long have you been running the twin and notoil because i could swear someone had a seem splitting issues with that filter as well. Basically the oil breaks down the glue at the seams.
  14. Motosportz CH Sponsor
    http://www.cafehusky.com/threads/no-toil-air-filter-cleaner-oil.24998/page-2#post-283094
    http://www.cafehusky.com/threads/no-toil-air-filter-cleaner-oil.24998/#post-226310
    http://www.cafehusky.com/threads/no-toil-air-filter-cleaner-oil.24998/page-2#post-255610
    Looks like the newer blue bottle cleaner is an issue with some filter glue...
    "I have been using the green stuff with no issues up to today, and I'm not sure the oil is the problem. I've cleaned these filters out at least 5 times with no issues using the no toil cleaner in a red "honda" bottle. Today, I switched to a bottle of the blue cleaner, and both filters instantly fall apart."
    "I had a DT-1 filter separate at the seams using No-Toil. They sent me a new one and said No-Toil was incompatible with their glue.
    Just a heads up. Great filter & customer service."
  15. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Never heard of jp1 anybody got a link?
  16. Motosportz CH Sponsor
  17. 454x Husqvarna
    Dunnigan,Ca.
    THANKS
  18. retromlc Husqvarna
    Kent,England
    TE 250i 2018
    Beta Evo 250 4/
    hi what springs did you use(brand and weight) and what weight are you,mine is bottoming out everywhere
  19. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    Yup, those are my pics above. No Toil will hook you up. I ruined 2 filters as shown above, they sent me 3 new ones. No issues since!
  20. Xcuvator Husqvarna
    Scholls Oregon
    yes
    After you posted that I called them and they sent me some too.:)
