07 50mm Marzocchi forks
Discussion in '610/630' started by rwarlich, Nov 29, 2010.
  1. rwarlich Husqvarna
    Tracy CA
    Does anybody know if the 2007 50mm marzocchi forks and triple clamp off a Husky sm510 will fit a 2009 Husky sm610?
    Thanks,
    Rich
  2. denny Husqvarna
    Central Indiana
    I don't know specifically, but...
    generally if the headstock bearings are the same It should work.
    You might need to press the spindle out of the 07 lower triple and press it into the 09 lower triple, if the length of the headstock tube is different.
  3. soarertoy Husqvarna
    Victoria BC
    Hi,
    I have 50mm Marzocchi forks, triple clamp and wheels from a 2008 TE 450 on my 2008 SM 610, fitted by 5th Gear, of Vancouver BC. They might be able to advise you.
    Cheers
    Richard
