07 on the Dyno
Discussion in '610/630' started by Fritzcoinc, Mar 2, 2009.
  1. Fritzcoinc Husqvarna
    Cypress, Texas
  2. rancher1 Husqvarna
    WA
    Wow the poster says the bike is stock which means he has been riding around for 12000 miles with the stock exhaust (you can see it in the pic ) which has a highly restrictive cat exhaust !!!
  3. Motosportz CH Sponsor
    My 06 gained so much power when i swapped the exhaust out it was ridiculous.
  4. Owen J Husqvarna
    UK
    Is the claimed figure of 52hp measured at the crank then?
  5. Coffee CH Owner
  6. rajobigguy Administrator
    So.Cal.
    Yes
  7. rajobigguy Administrator
    So.Cal.
    My "SOTP" dyno indicates about about a seven HP gain when properly jetted and a good free flowing exhaust.:D
  8. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I wouldn't take those numbers to heart. I've spent some time running bikes on a dynojet and there are a few things that I can see from this picture that are making a big difference with crank vs. rear wheel numbers.
    BTW- I wouldn't be surprised if the 450 made more power than the 610.
  9. Motosportz CH Sponsor
    True on the forast part.
    As for the 450 -v- the 610. I own a 06 TE610 with a Barrett muffler on it and a bone stock (motor wise) TXC450. The 610 has way more torque and bottom end and i would guess more power everywhere. The 450 might have an edge on top but i doubt it. I think my 610 would leave my 450 for dead in a pavement drag race. Might have to do that one day soon.
    I have no problem hanging with and leaving these two 650 twins...
  10. rajobigguy Administrator
    So.Cal.
    Most of the "tests" that I have seen indicate that the 450 and 610 are pretty close when it comes to peak HP but the 610 delivers it over a much broader rpm range.
    Yeah Kelly I think you are right that in a asphalt drag race the 610 probably has the edge over the 450, like the old adage goes " there's no replacement for displacement".
  11. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    Let me know if you need any "help" with that... :lol:
    I'll hold the camera while you and Shane race...
    :thumbsup:
    Later,
  12. Motosportz CH Sponsor
    Shane the looper.
  13. Wetdog Husqvarna
    Tsawwassen, BC
    I was always told by a local dyno guy that knobbies and dyno's do not work well together. I watched his 45o KTM gain 6+ hp over a knobby when he spooned on a street tire.
  14. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yes, I agree. There's a knobby on there and they'll kill a run. I've also found gearing has a huge effect.
    450 vs. 610, Just as stated above, I think the top end HP number would be close, but the 610 will make WAY more torque and HP over a much broader range.
    BTW- I think the 610's basic motor design is a great one and that's why it's still around. Husaburge and KTM basically used spin off designs to get into the 4 stroke market. It was the first truly competitive, light weight four stroke motor, IMO.
