07 te450 fan mounting eletrical question
Discussion in '4 Stroke' started by tallywacker, Jul 31, 2009.
  1. tallywacker Husqvarna
    SW Oregon
    Need some help please. I dont want to fry anything.
    I purchased a Trailtech light with it's own headlight switch mounted directly to the battery. That free'd up the old lo/hi beam switch. So my idea is to wire a 08 TE450 radiator fan to the old lo/hi beam switch for manual fan on/off. The fan is mounted, I have the old headlight wires coming out of the rats nest. There are 5 wires:
    white, blue, black in one sheath
    yellow/red, blue in the other.
    Looking at the pdf shop manual wiring diagram, I cannot tell what to wire to the fan, and then I dont want it to be harmful as far as wattage goes.
    So, to simplify my questions,
    1. What 2 wires do I send to the fan to turn on the fan in the high beam position?
    2. Is this a safe idea?
    Wish I was smarter about this stuff. Thanks,
    ----John
  2. tallywacker Husqvarna
    SW Oregon
    I put a volt meter on the wires and did not get anything more than 1.5v.
    I wonder if I need to have the circut closed on all 5 wires to get more volts.
    Anyway, here are some pics of the old headlight wires if anybody has any tips for wiring them to the fan, (black and red).
    Thanks,
    ----John
  3. tallywacker Husqvarna
    SW Oregon
    The saga continues.
    I just fount the white and blue power the high beam. I wired them to the fan, and guess what, it dosent turn unless you give it some gas.
    So, I will see about running a new set of wires from the battery to the switch and then the fan.
  4. tallywacker Husqvarna
    SW Oregon
    Done.
    In case anyone ever wants to do the same, I ran the hot wire from the trailtech headlight hot just past the fuse directly into the highbeam switch wire (white) then back to the fan with the (black/green). The ground goes directly from the fan to the battery. It came out very clean.
    It was easier than I tried making it at first.
  5. oregontrail Husqvarna
    Jacksonville, Or
    2012 350 XC-f
    1999 Buell X1 Lightning, 2004 KDX220
    On my 07 TC with electric start, I plugged into a white connector that looked like a headlight switch and used that. Picked up a connector from the Husky dealer and plugged in. :applause:
