07 wheels fit on an 09?
Discussion in '4 Stroke' started by Riksha, Apr 16, 2009.
  1. Riksha Husqvarna
    So Cal
    Would the wheel set from a 07 TE450 fit on 09 TE450 w/o exchanging brake discs? Seen it done on an 08 since the discs were the same. thanks
  2. Bobby Husqvarna
    Woodstock, GA
    '13 TXC310Rx2,
    G450X, HP2E, 10 R12ADV, GasGas280
    no prob, the wave rotor just looks different but fits the same.
  3. foxracing Husqvarna
    Singapore
    Hows the interchangeability of wheels like between the 05-09 + TE-SMR + 250-610? Minus the rotors, I'm pretty sure the hubs are identical right? So all of them should be able to fit each others wheels?
  4. scoobywrx05 Husqvarna
    Warren PA
    The axle diameter is smaller on the 05 and 06's compared to the 07- 08-09 axles, but I have heard you can change the bearings over to the 07-08-09 bearings because the outer diameter of the 05-06 bearings is the same as the 07-08-09's. This is what I've heard and don't know for a fact if it is true or not. You would also need the axle spacers from the 07-08-09 if your going to use those bearings and vice versa if your if your going the other way. The triple tree is also narrower on the 05-06 bikes than the 07-08-09's which causes some problems when taking a 07-08-09 rim and putting it on a 05-06 bike. Again,,this is what I've heard and don't not know what parts of it are factual or false.
