08 Sm610 valve check spec?
Discussion in '610/630' started by no_rice, Mar 8, 2015.
  1. no_rice Husqvarna
    2008 sm610
    lotsa Buells & a 65 Bultaco Metralla
    I'm in need of doing my first valve check on my 610, and was wondering if anyone knew what the spec was suppose to be? It will be the first time I have done it, and the first time the bike has gotten one.
    It's a little past time to do it, but not thousands of miles or something. Also does anyone have a link to a good service manual? What I've kept seeing people say is the factory ones aren't really very good anyway?
    Also I know I need to take the cam chain tensioner or and see what that looks like. How many notches on that before you guys recommend changing?
    I guess, actually any info or tricks to make things easier would be helpful... I really need to take the whole dang motor apart and replace every gasket... the thing had been seeping oil from almost everywhere since a couple hundred miles. I've snuggled up some of the stuff I can reach but it needs more then that. Ugh. Thanks for any insite
  2. Spice Weasel Husqvarna
    UK
    08 SM610
    .002" .05mm all round
    I use a piece of pvc pipe in the plug hole to find TDC and just turn the rear wheel
    JonXX likes this.
