08 Te 450 , manual fan switch {bypass thermo switch}
Discussion in 'General (Main)' started by Rich DiMauro, Aug 19, 2015.
  1. Rich DiMauro Husqvarna
    2010 wr 250
    Recently purchased an 08 te450 low miles that wasn't ridden very hard but has some updates... power up kit.oxyge sensor removed..looks a little rich by the black on the exhaust tip but im fine with that .. If i like the bike enough ill get an oversized clear tank over winter... I have a trail tech mounted instead of the stock speedo --- The Temp sensor is on the hot side after waterpump before the radiator... On a hot day,80 /85 degrees, on the road im 165-185 -- IN the Woods im running anywhere from 210- 235... 10- 25mph , Good flowing single track - I did see 235 at one point stopped for a bit waiting then pretty much maintained in the 220's - Im not exactly sure how hot is to HOT! Although the bike always ran perfect { only did 1 30 mile single track ride with it so far... I love this motor...xr 650 smooth tourque on bottom but runs like motorcross 450 up top! its geared perfect for the woods,1 down from stock in front, may be a little short on the road , but i can deal...I had a 2010 wr250 2 years ago and loved that motor as well!
    Now i understand after the motor before the radiator the temps is a little higher --- It did puke spits of antifreeze on the motor out of the overflow bottle not bad though just a little..I have the stock radiator cap, i realize i could do Evans, and a highflow pump, and hose upgrades,,, Im pretty confident it does not have the stock hoses... they all look like they have been cut to fit.. and the radiator fluid is more of an aqua blue greenish.....But is there a seperate thermo sitch for just the fan or is that also which controls the ecu? and the location? I would like to switch the fan to leave on in the single track ,but i dont want to fool the computer unless thats not a problem.... Im feeling that it comes on a little late and by that point its already very hot... a quick burst of speed in the open cools it right down... Sorry if this has been discussed i looked! but i also know temp sensors might have changed locations with different years of fuel injection....
  2. ghte Husqvarna
    Bright, Victoria Australia
    Drain your coolant, flush your radiator and put engine ice in. I have never had a heating issue in my 510, 2x 450's or 2x310's I ride hard ST in steep country in Australia often in the high 80's/ low 100's. I am also 250 pounds stripped.
    bigjon likes this.
  3. bigjon Husqvarna
    twin falls, idaho
    1996 WXC410 2000 TE410 2008 TE510
    Yamaha FJR 1300 Polaris 500
    Engine ICE? THis is good to know. Thanks for the tip. Next time I change fluids on my 510, that is what I will put in it.
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    if you are going to spend the money on engine ice, its a better investment to switch to an actual waterless coolant. check out the xf2 stuff from our own zipty racing..
    xf2 will build no pressure in your system, hard to boil over that way. cafe husky users get a discount at zip ty as well..
    engine ice is a good upgrade over normal coolant however, but i have switched everything to waterless now.
    http://www.cafehusky.com/threads/zipty-racing-xf2-new-racing-coolant.46533/
  5. Rich DiMauro Husqvarna
    2010 wr 250
    Thanks for the replies - the bike ran cooler the next time I took it out .. I will drain the system over the winter and go waterless - I feel if that fan came on a bit sooner it would be much less prone to running hot - I'm also on the hit side where my trail tech is Hooked up so it'll be a couple degrees hotter on the gauge
