08 te450 Fork oil weight and lvl
Discussion in '4 Stroke' started by Lucifer2466, Mar 31, 2010.
  1. Lucifer2466 Husqvarna
    austin texas
    I am doing my own front forks, for now...
    Trying to see what weight fork oil and level people are running in there's or maybe what they can suggest to me. I'm a energetic/crazy/178 - 182LB "without gear". "weight luxuriates in martial arts"..
  2. Lucifer2466 Husqvarna
    austin texas
    and I'm doing standard rough texas enduro plus mx
  3. Droolsport Husqvarna
    Arizona
  4. Lucifer2466 Husqvarna
    austin texas
    10 W oil ,, isn't that a little extreme ?? , I heard of a few putting 5w oil in
  5. Droolsport Husqvarna
    Arizona
    I am looking to keep it up in the stroke more, limit bottoming and slow down the rebound more. Easy to change back to the 7.5 weight if it doesnt work. I will post my impressions when I ride next.
  6. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    My tuner ran the height really high on mine, 85 mm, but it's already been revalved.:excuseme:
  7. ghte Husqvarna
    Bright, Victoria Australia
    Standard height is circa 120mm and vary this by your weight and riding style. The Oil weights is also subjective it typically ranges from 5 to 10.
    I run 100mm from the top and 5 weight from Motul. Note: I understand the oil weight can vary from brand to brand quite significantly.
  8. Lucifer2466 Husqvarna
    austin texas
    I'm not planning on revalveing them yet, I don't really know the bike yet... Anyone have any suggestions on stock forks,
  9. Lucifer2466 Husqvarna
    austin texas
    I'd sent them to, les but, washington is sooooo far from texas, I wouldn't see my forks for a month
  10. Lucifer2466 Husqvarna
    austin texas
    anyone have any idea on fork oil and lvl, my seals arn't in yet. So I have a little time left for an answer
  11. SFTE450 Husqvarna
    San Francisco
    It may take some experimentation on your part. I like to ride knarly, rocky mtn single track. At 215 lbs I am running 5wt at 100mm with stock valving. This would not work for MX or the dessert. But it does allow the forks to track and not deflect off rock and roots but absorb it on my rides.
  12. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    Lucifer2466- if that is your real name?:D
    If 7 is the weight and 120mm is stock height and this is where you are now at, what do you want to change in performance. weight of oil effects dampening: less is less more is more. Oil height measured by the air space: 100,110,120,130 effects "air spring weight" more air= less spring, less air=more spring. the air chamber is progressive
    You probably should have an idea of what you want to change- for your situation- what works in tight single track does not work on an MX track usually and vice versa.. I don't know that a set up that works for one guy will work for you- its not as transferable as some topics. Its not like there is a specific common problem that everyone is trying to tune out of the Husky suspension.
    Personally when I change my fork oil of my 09TE450 I want it exactly the same as stock- I love where its at. I have done street, gravel, grass track , 2-track, single track,Logs, rocks, mud, sand, Jello pudding clay, small mx tracks in woods and private trac.... whatever is in front of me and it does it all without a complaint from me. But- I am not an A rider or a professional- don't do martial arts- and am Lazy, Sane, and Fat:busted:
  13. Lucifer2466 Husqvarna
    austin texas
    Pimpen
    Jeremy is the name (-:
