The wire seems to be directly connected to the electric coil. Does the entire component need to be replaced? Thanks - Chad
IS it just a push-on pin-style connection? What I can see of the exposed inner wire looks quite corroded. If I can just cut a c.h. back to expose good wire, push it on and add a dab of glue at the wire/boot to prevent 'slippage' I'll call it a day. There just isn't any slack and I was a-feared that the wire would easily back-out if there wasn't some sort of soldered or clamped connection...
I have not taken appart the Coil wire to spark plug boot on the husky but- traditionally the connectors screw into the wire- I don't expect this to be different. If you shove it in I don't think it will stay- if you glue it after shoving it in I think you'd have poor connections before it fell appart... cut off about 1/4 inch and start fresh- BTW: This question would have done better in the 4-stroke section or the common topics section.
