08 TE510 New 15T Counter Sprocket but lost speed odometer?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Puckerbush, Jun 25, 2015.
  1. Puckerbush Husqvarna
    Anaheim Hills, CA
    '79 390 CR and '08 TE510
    Just bought a new chain and went from a 14T to 15T counter sprocket and lost my speed odometer and odometer. I wanted to see if the revision would affect the speedometer, so I attached my GPS and noticed the speedometer was registering 40mph, then 20mph then 0mph. It lights up but the speedometer shows "0mph" and the mileage stays the same. Is the pickup for the speedometer off the countershaft sprocket?. Any thoughts?
  2. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    You should be able to follow the speedo cable to see where the pickup is. Usually either mechanical or magnetic on the front axle/wheel. Sounds like the speedo is getting power, so check and clean both ends of the cable. In general, if it's mechanical lube it and if it's electronic check continuity. All else fails RTFM!
    :cheers:
  3. Puckerbush Husqvarna
    Anaheim Hills, CA
    Thanks NCSteve. I followed the wire from the front wheel near the caliper up to the connector and found one of the two wires broke. Fixed now and works fine.
  4. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    :thumbsup: You're welcome, glad it worked out so easily.
