125-200cc '09 125 & Lectron Owners
Discussion in '2 Stroke' started by slo rider, Mar 28, 2013.
  1. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    Any '09 125/144/165 owners out there who have installed a Lectron, what throttle cable are you using? My stock cable is about 1/4" too long with both the throttle housing and carb adjuster all the way out.
  2. Motosportz CH Sponsor
  3. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    Hey Matt!
    I installed mine with the stock cable and like yours it is adjusted all the way out. I have wondered if it is costing me power at the top end but I have not pulled it apart to verify that the slide is going all the way to the top.
    I need to bug Kelly about a new cable.
    Later,
  4. earl61 Husqvarna
    Imdiana USA
    You can always tie a not in a cable that is to long just above where it hooks in the slide. I, no thats crude but works well !
    jmetteer likes this.
  5. DaveG321 Husqvarna
    Easton mass.
    I installed the KTM 250 2 stroke cable by Motion Pro and it fits great,also Walter gave me this idea is too zip tie the cable at the head stay mount and it helps the cable from pulling away from the carb in which none of us wants that to happen.
  6. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    Well it turns out Motion Pro has a "stock" cable for the 09 125 that has a 10mm longer housing which should be just what I'm looking for. Will report back once it shows up.
    typeone likes this.
  7. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    thanks for posting this thread, good info :thumbsup:
  8. DaveG321 Husqvarna
    Easton mass.
    The Motion Pro KTM250 cable has a bout a half inch less cable and about 2 or 3 inches of housing which I think works perfectly for my 09 WR165,I use FLEXX BARS and now have just the wright amount of cable and they cost about 15.00 dollars.
  9. placelast Husqvarna
    What year of KTM 250 cable?
  10. DaveG321 Husqvarna
    Easton mass.
    02 or newer.
