250-500cc 09 300
Discussion in '2 Stroke' started by bsh7680, Aug 24, 2011.
  1. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    Had an 09 WR 300 for about a year only problems I have found is starting and seems to stall a little easy. Will a flywheel weight help this or do I need to do something esle. I love everything else about the bike, but need to get this figured out to quit thinking about those darn orange bikes I came off of!
  2. TROFFER88 Husqvarna
    Camas Wa
    You need to look at your jetting
  3. hogwackr Husqvarna
    pennsylvania
    18 TE 250
    13 HD Street Glide
    +1. You can ride these things like a tractor if you have your jetting right!
  4. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    I swapped out my carb for a pre jetted kehin and the bike purrrrrsss now.
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Probably the pilot is too rich, I'd at least start there.
  6. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    I agree that it is most likey a jetting issue. I also have an 09 300. I swapped the carb to a Keihin pwk 38 and it is worth every penny. I was jousted off my bike by a fallen tree the other day and flipped over backwards and upside down. My bike didn't stall As I was rolling around in immense pain, my friend rolled up and said "Your bike is still running...That is amazing...I can't believe your bike is still running" True story. With the proper jetting the motor will run to an extremely low rpm without stalling.
  7. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    I sent my 09 WR300 Mikuni to RB Designs www.rb-designs.com and their work crispened it right up on the bottom end.
  8. RobNewy Husqvarna
    Australia
    Mine is exactly the same.
    http://www.cafehusky.com/threads/09-300-idle-speed.19420/Try some of these ideas.
    What is your current jetting?
