I have an 09 te 250 with the 310 kit also have a jd tuner. I ve tried alot of different settings but can not get rid of the idle pulsating and low end bog. any ideas?
When did the symptoms start? Did it run good for a time after the 310 kit, did it run good for a time after the install of the JDtuner?
ya it ran fine after the kit was put on (George at uptite did it) Started noticing it a few months ago. I had the tuner on before the kit and used it from day one after the kit was on.
How many miles/hours on the bike? Does the bike have the OEM fuel pump, and have you pulled the pump assembly and looked at the pump strainer.
bike has about2600 miles and about 1100 since the 310 was out on...have not pulled the pump assembly if it was clogged a little you think it would create the low end bog a pulsating idle?
I have not personally had those exact symptoms, others would advise you to reset your TPS, which I have never had to do, so i don't have any experience with TPS related issues. I have a fair bit of experience with bad fuel pumps, they cause alot of different problems.
