09 610 engine noise
Discussion in '610/630' started by bronzebronco94, Jan 29, 2013.
  1. bronzebronco94 Husqvarna
    NW New Jersey
    06 TE610 09 SM610
    Rokon2x2, KZ1000,
    Ok, so ive got just over 12000mi. on my sm610. its been maintained, adjusted and serviced when called for. i noticed a different sound from the engine the other day. The noise isnt very noticable at cruise or when under load. It sounded to me like a knock up top when the bike first fires up and the last couple rotations as i killed it. I was hoping that the cam chain was out of spec or something was obviously wrong. But the acct was only out 7 or 8 clicks. it looked fine. im not an expert, by any means. i have done a bit of searching on my end. i found a common problem with these bikes is the rockers get a bit of play laterally. now, i do have prolly .015 of side to side play in the exhaust side rockers. i have also noticed a little scoring on the exhaust side cam lobe and the rocker roller. should i shim out the play in the rocker? i have included pics(from my phone sorry) of my cam chain slider acct side. is it normal to have this kind of wear? without measuring it, it appears to be close to .060 deep. ive not had this bike this far apart before, and i didnt tear my 06 this far to do the camchain and related stuff. ive given the piston, connecting rod, and everything i could, a good shake around and it feels tight. any thoughts would be appreciated.
  2. bronzebronco94 Husqvarna
    NW New Jersey
    06 TE610 09 SM610
    Rokon2x2, KZ1000,
    nobody has anything to add?does this wear look normal? i know some of you must have had your huskies apart this far.
  3. Gav Husqvarna
    West Sussex, United Kingdom
    SM610
    GSXR 600 SRAD:Sold ZXR 400 H2:Sold
    Sorry I haven't taken my bike apart that far.
    Did you find out whether it was within tolerance?
