'09 and the Y pipe affliction
Discussion in '4 Stroke' started by husky123, Jun 2, 2009.
  1. husky123 Husqvarna
    Leesburg, VA
    Am I to ASSUME that the '09's still suffer from the coolant flow affliction as previous models. Uptite Y to the rescue?
  2. fury1 Husqvarna
    ma.
    I bought the Y-pipe from uptite,but havent used it yet,my bike doesnt seem to get that hot??
  3. cbreakin Husqvarna
    SoCal
    2009 TE510
    They sure do. I just installed the uptite "Y" on my 09 the other day. The bike wasn't suffering from any overheating issues I was aware of prior to the installation on the "Y" but, when you look at the flow characteristics with the stock "T" installed the design is essentially by-passing the right radiator therefore forefitting the full potential cooling capacity of the system. Seems silly not to have a Y there.
  4. husky123 Husqvarna
    Leesburg, VA
    Thanks fellas. My goody bag should be arriving from Kelly any day!
  5. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    Hmmm. The right rad has the coolant fan. Could be because the only place to put it. I did the Up-tite "Y" also on my 08 TE450. The fan still comes on (hot day, slow tech or sand) It's a better mod for sure.
  6. kpie Husqvarna
    Utah
    Uptite Y
    OK so I'm clueless....I'll admit it. Just got the 'Y' and there are no instructions. Has anybody put out a 'how to' thread on this? I can't find one. I'm assuming the tank must be removed and coolant drained? I have the '09 TE 510. Thanks.
    :excuseme:
  7. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    Remove tank, fuel line quick connect and wiring. (Be very careful of the fuel pump plastic pipe on bottom of tank)
    You may loose a little coolant but not that much.
    Get two new SS hose clamps and throw the pinch clamps in your adventure bag. (They work in a pinch.) ;) Loosen the hose clam coming off the pump housing so you can slightly rotate as needed to remove the pinch. I actually cut a ½ inch off for less of a pinch on this hose.
    Any more questions, just ask? :cool:
  8. ramz Husqvarna
    Salida, CO
    Check it out: Y
    Yeah, click the letter Y above; it's a linky.
    See also the radiator crossover hose mod...
    Click the pics to supersize.
  9. kpie Husqvarna
    Utah
    Ahhhh bless you. Thanks for the help!:thumbsup:
