09 SM610 GREMLINS
Discussion in '610/630' started by bronzebronco94, Oct 12, 2011.
  1. bronzebronco94 Husqvarna
    NW New Jersey
    06 TE610 09 SM610
    Rokon2x2, KZ1000,
    Last night the (until recently) trusty husky started doing very strange things. on steady throttle the red over rev warning light would quickly blink. i noticed it happen a couple times. shortly after the neutral light blinked at me. the bike then shut off for a split second, completely off, headlights and all. i was able to pull it over and it seemed to subside. i checked over everything roughly. no loose wires, blown fuses, or anything obviously out of place. i fired it back up and rode for 5 mins and it went haywire. all of the indicator and warning lights were flashing at random, like a light show through my shield. the bike was also intermittently dieing as before, but it would come right back to running for about 20 seconds. at that point i shut it down and pushed. lucky for me it happened up the street from my shop.
    a quick back story, the bike has 7100miles on it. its got a couple usual mods, LV slip on, airbox delete, power commander 5 with autotune and lcd screen. up until now it hasnt skipped a beat, aside from bouncing off limiter on the occasion. im more than a little concerned about being stranded from a fuel injection issue. ive heard rumors that the flashing is some sort of code? ive not seen anything definitive. has anyone had any issue with the kill/start combo switch?
    the shutting off like it was make me think faulty switch, thats where im diving now.
    any thoughts, input or directions to go would be great!
    update, just inspected the combo switch. appears good. dry, no corrosion and smooth contact. hmmm:thinking:
  2. LRPct Husqvarna
    NW connecticut
    Battery?. Coil?.
  3. bronzebronco94 Husqvarna
    NW New Jersey
    06 TE610 09 SM610
    Rokon2x2, KZ1000,
    well, i checked the battery and went over a couple more things. i unplugged the ignition switch from the harness and found some corrosion in the plug. not much but some green and blue stuff on the pins. also tried to start it today and the battery icon lit up then the neutral light started flashing then stopped. immediately after the flashing stopped, the fuel pump primed like normal so i tried again to start it up. when i hit the start button i heard a strong click of the starter solenoid and nothing. the bike shut off like it did on the road, lights and all. major buzz kill!
  4. LRPct Husqvarna
    NW connecticut
    What do mean "checked the battery"? Did you load test it.. sounds like battery or main power switch, or main switch fuse on left side.
