hope someone can help! After about 20-40 min of riding i get a fail code on the dash i've herd that its cause is my MAF sensor idk how true it is but if someone could please tell me how to remove and clean the sensor it would be greatly appreciated aswell as any other idea anyone might have the bike seems to run normally even with the fail code on. also if i turn the bike off with the key and restart it goes away for a min then come back
There are other threads about this problem, mine ('10 TE450) has the same issue, bike runs fine with the 'FAIL' remaining on the display. Luckily it is still under warranty and I will be getting a complete new wiring loom.
I would have it hooked up to Ibeat to find the source of the fail. Sorry I have never heard of anyone cleaning the MAQ sensor, personally I wouldn't touch it at this point. If it runs fine- like Krezz said- its probably a short or open cicuit. Check the plug inplace for where the "tilt sensor" would be.
Finally got my bike back with new updated wiring loom, only looks like it is more protected and sealed. Hopefully I don't have to post regarding this problem again.
Check out this thread, hope I did the link right http://www.cafehusky.com/threads/2010-te510-problem.15336/#post-173372
so ive cheacked he connection for the dummy plug where the tilt sensor would be i believe and it looks to be ok next step i would assume is to replace that resistor?
