09 TE after market blinkers?
Discussion in 'General (Main)' started by NewHuskyGuy, Nov 2, 2009.
  1. NewHuskyGuy Husqvarna
    Riverside, CA
    Hey all,
    I went this weekend to Ocotillo Wells and experienced my first broken blinker issue. I fell but actually kicked it off with my boot getting off!:banghead: Husky blinkers are a little bulky so what is everyones choice for after market ones? KTM ones look like they flex and they tuck in better. LED would be cool also. I would appreciate the feed back. Thanks
  2. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
  3. RumRunner Husqvarna
    Yucaipa, CA (SoCal)
    2007 TE 450
    I have these too and am also very happy w/them. The have taken a beating and bounce back well. They also fit the lines of the bike better than the large stock ones.
  4. BCVisin Husqvarna
    Temecula, CA
  5. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
  6. Doormandan Husqvarna
    So Cal
  7. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    I think you should break the stockers first...at least one of them.
    I've only bent one so they're still good to go.
  8. CKPC Husqvarna
    EastBay (NorCal)
    I just have cheap blinkers I picked up at CycleGear. I paid like $12 and they are flush so I mounted them on a couple pieces of flexible plastic and just bolted the plastic in the orginal spot. You can see the blinker just under the rear fender. The plastic is so flexable it can be completely folded under.
    A "Coffee" idea from a while ago!
  9. rabskyline Husqvarna
    Sunshine Coast,Queenslander !!
    2014 te250r
    Yer maw !
    or you can do my mod.... swapping brackets and lifting them up and inwards.. works well.. also, i have broken 2 lens before i moved them up and in ! much safer now.. but yes, the newer models are horrid and bulky...
  10. hipsterdufus Husqvarna
    KS
  11. Vansmack Husqvarna
    Los Angeles
    +4 for the electrosports
  12. NewHuskyGuy Husqvarna
    Riverside, CA
    Thanks for the ideas everybody. I like both lights and i definately like the LED part! Are the relays hard to install?
  13. RumRunner Husqvarna
    Yucaipa, CA (SoCal)
    2007 TE 450
    The Electrosport relay is very easy to install. You have to change the connectors on the wires but other than that it's a breeze. I did notice that after I added the relay the blinker indicator on the speedo doesn't blink now it stays solid while the blinkers are on. I didn't put the relay on until I put the LED's all around. W/o the relay the lights just blink faster.
  14. Coffee CH Owner
    I remember that!
    Anyone mind if I move this into common topics since it is about lights?
  15. Muddy Waters Husqvarna
    On the islands
