09 te bars/handgaurds ? Taperlock Insert Set dont fit
Discussion in '4 Stroke' started by 440rev, Mar 20, 2010.
  1. 440rev Husqvarna
    IL
    What do u guys do to make them fit? shave down the taperlock Insert or drill the bars, or is there a taperlock Insert for the stock bars? I got the Evolution Debris Deflectors.
    Thanks
    Randy
  2. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    We drilled the bars, stepping up the bit gradually until the inserts fit.
  3. ironram Husqvarna
    SD
    what phoenix said. i stepped up to 9/16 so if you gona cut your bars narrower due it before you drill.
  4. 440rev Husqvarna
    IL
    Thanks, so I need a 9/16 bit?
  5. billknj Husqvarna
    New Jersey
    I just drilled the 9/16 without stepping up. Wreaked havoc on the bit, but it worked.
  6. seanoj Husqvarna
    Los Angeles
    I used a masonary bit. held up well and worked quickly. I think I used only two steps 1/2? and 9/16? I might have gone all the way out to 5/8"
    I think you can get inserts that will fit, if you look around. I found some a few months after drilling mine (for Acerbis Ralley Pros).
    I sometimes wonder how much strength I might have taken out of the bars by drilling. Probably compensated by adding the inserts, but I still wonder...
  7. R_Little Husqvarna
    NJ
    stress risers from drilling but bars never break at the ends....they break at the bends if at all.
  8. 440rev Husqvarna
    IL
    I just ordered some of the Acerbis Ralley Pro taperlocks.
