I am trying to get the TMX carb jetted correctly and I'm really close except for finding the main. Maybe someone here can help.
Here are my current settings:
Elev. 6000 ft
Temp. 70 deg. (all of my jetting tests have been near the same temp)
Pilot 30 (AS 1 1/2 turns out)
Needle GAY needle (3rd clip)
Main 430 (have tried 390 to 450)
I have it running very well up to about 3/4 throttle. With all of the mains I've tried, the result is always the same. When I take it through the gears and hold it wide open on a dirt road, above 3/4 throttle, the power falls flat and it doesn't scream on top like it should. I'm not a jetting expert but to me it feels like it's a lean condition. And the plug is dry and light gray also looking lean. At my elevation, going to higher than a 450 doesn't seem right since the stock main was a 460. And the last time I tried it, I was wide open and reached down and pulled the choke and it didn't change anything. When trail riding I'm rarely wide open and I don't even notice that the main isn't right. It has good power off the bottom and throughout the range when riding. I can ride all day and get very little spooge on the silencer, but when I do my wide open runs to check the main, the pipe gets wet with oil running down it. I was thinking that this indicated that it was rich at wide open but that's not consistent with the plug reading. So could this be just residual oil coming out of the exhaust?
I was told to try a plug without a resistor - B8ES instead of BR8ES and it still does the same thing.
I have checked and adjusted the floats.
I have not checked the power valve. I can feel when it opens when riding and there is a delay in closing when the rpm's go down. Is this normal or could there be a problem there?
Is it possible that even at 6000 ft I may need to go higher than stock on the main jet? The service manual chart recommends 390Main/35Pilot at 5000ft/50degrees. The 35 Pilot was rich.
I've been very methodical about only changing one thing at a time and I'm not sure what to do next from here. Check PV? Keep trying richer mains? Something else? I'm really close so not giving up on the TMX yet.
Elev. 6000 ft
