250-500cc 09 WR250 fuel mileage
Discussion in '2 Stroke' started by lankydoug, Sep 11, 2011.
  1. lankydoug Husqvarna
    MO
    WR
    TM 300en
    This topic has come up in several threads so I thought I would put some numbers to my experience and see how it compares to everyone else's.
    I rode a tank down to reserve and then drained the remaining fuel into a measuring cup to see how much fuel was left after switched to reserve. I had 1 3/4 quarts of fuel left once I hit reserve (that's with the bike level) if I was to keep tipping the bike to the left I'm sure I could have gone further before reserve.
    I was riding on my property which consists of 80% tight singletrack with logs roots rocks and creek banks. It is more suited to trials riding and I'm almost always in 1st gear. I have a couple of small grass track type openings where I may get in 4th for a split second before having to get on the brakes but I spend less than 20% of my time in that area. (Sometimes I wonder if I would have been better served buying a trials bike.) I realize my fuel mileage won't be as good as others simply because I'm almost always in 1st gear and that's not economical. An A class rider would probably be in 2nd instead of 1st and since I've geared down to 13:52 I have used 2nd more than I used too.
    So here are my numbers;
    I get approximately 42 miles before I hit reserve.
    A stock tank holds 2.2 gallons
    I should get about 9 more miles after switching to reserve.
    If I rode in a more open area I believe I would get much farther on a tank but would like to hear what other have experienced.
  2. schrode Husqvarna
    seattle
    i have an '08 wr 250 with the ims 3.4 gallon tank. in 2nd and 3rd gear s.t. i get around 75 miles per tank.
    lankydoug likes this.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    That seems to be on par with the mileage per gallon I'm getting.
  4. corey43 Husqvarna
    Central MO
    2014 CR 125
    Where are you from in Missouri?
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Rolla is where I live now.
