250-500cc 09 WR300 6 speed conversion
Discussion in '2 Stroke' started by Rob578, Jan 22, 2012.
  1. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    Finally plan to get started on this project, it's finally turned wintertime around here.
    Here's my first problem:
    What is the best way to get the loose needle bearings back in? One of the gears slipped off the 360 layshaft and sent all the needles onto the floor. Do you grease the shaft then slide the gear over them or slide the needles back in through the slots on the shaft, neither one of these solutions is working for me at the moment.
    Looking at the parts fiche they show up as part # 800027690 with a qty of 68, they are used in two places so am I safe to assume the each takes 34? Will keep this thread updated with my progress or lack thereof
    Thanks for your help
  2. wallybean Mini-Sponsor
    Montana
    Rob,
    Having done exactly what you did the first time I did this, I can sympathize. At least mine didn't make it to the floor. Use a really sticky grease and work all the needles back onto the shaft. Just be patient sliding the gear back over. I always put a zip tie on the shaft end outside the end gear on the 6-speed to keep it from falling off anywhere before you install. You really can't get the number of needle bearings wrong. You will either have enough room for one more or you won't. They shouldn't be ultra tight. One more thing you should do is take your micrometers and measure the total width of your 5 speed lay shaft gear cluster with shims and you now want to match that dimension with the 6 speed. Husky has listed many different width shims for this purpose. you are looking for +or- .005". If you need a shim width and can't find it let me know as I might have one. Your clutch shaft cluster is captured by the clutch and is not adjustable.
    Let us know how the "sticky" grease works,
    Walt
    PS, I use Amsoil GLI 2 all purpose grease for this. Pretty sticky but will allow oil penetration and wash out. An offroad cat grease is really sticky but also will want to inhibit oiling. JFYI
    lankydoug and J.R. like this.
  3. Rob578 Husqvarna
    Atlanta GA was CA
    U r the man Walt
    Xcuvator likes this.
  4. Rob578 Husqvarna
    Atlanta GA was CA
    Got started on this project today and realized I don't have the correct fly wheel puller. Just to confirm is it a 22m x 1.5 RHT?
    Thanks
  5. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I will be starting a conversion soon and the puller that BMP set me up with is 22X1.5 RHT.
  6. TROFFER88 Husqvarna
    Camas Wa
    Steve , that is great news you can install mine too
  7. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Since we have Uncle Walt to call in case of trouble, we should be fine.
  8. Rob578 Husqvarna
    Atlanta GA was CA
    Thanks guys
  9. Rob578 Husqvarna
    Atlanta GA was CA
    All taken apart, ready for reassembly
  10. Rob578 Husqvarna
    Atlanta GA was CA
    Something is screwy here. That can't be enough shaft to get a sprocket on
    and no, the cases aren't bolted back together yet
  11. Xcuvator Husqvarna
    Scholls Oregon
    yes
    It looks about right. I think you are just used to the way the 5 speed shafts stick out.
    My shaft sticks out .310" from the spacer.
  12. Rob578 Husqvarna
    Atlanta GA was CA
    Mine is .300, certainly looks whacked.
    Thanks for the reply
  13. Rob578 Husqvarna
    Atlanta GA was CA
    Ok, which one goes where? the one on the right has a B stamped on it DSC01025.JPG
  14. wallybean Mini-Sponsor
    Montana
    Rob,
    You can't get it wrong. If you do it will not shift. Its been 4 years since I have done one so which one goes where is not in my memory any longer or nowhere it can be accessed.
  15. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Maybe this will help.
  16. Rob578 Husqvarna
    Atlanta GA was CA
    I finally figured it out, if you mix them up neither one fits in the shifter drum right.
    On to my next issue.
    The tensioner on the shifter just doesn't fit right on the star pawl. I'm using the 360 arm and the 5 speed spring but it looks like I need the fab up a spacer to center it on the pawl. Without one it sits too far inboard and the pawl hits the arm instead of the roller.
    I did stick the cases back together and now have all six Gears!!!
    How much play should the output shaft have? Not measured it but I'm guessing it's around .1mm
    Really appreciate everyone's help
    Walt ignore my previous email
  17. Xcuvator Husqvarna
    Scholls Oregon
    yes
    You shouldn't need to make any spacers. I had the same problem till I got the arm in right.
  18. wallybean Mini-Sponsor
    Montana
    Rob,
    I think I mentioned it in an e-mail, but you need to make sure you got the o-ring in first when putting the outside spacer on the output shaft. If the o-ring isn't in their it will weep tranny oil.
  19. Xcuvator Husqvarna
    Scholls Oregon
    yes
    [quote="Rob578, post: 212695, member: 3199"
    /quote]
    .1mm is a little tight.
  20. wallybean Mini-Sponsor
    Montana
    I think .005" is what Husky wants, so you are ~.001" less than that. My guess is that you are fine. A friend of mine did this about 5 years ago and installed it tight with no play. It was a bit stiff but once it broke in worked ok. He didn't have any shims to adjust. I expect that bike to eventually have problems with the out put shaft case bearing on the drive side.
