250-500cc 09 WR300 rear brakes
Discussion in '2 Stroke' started by KXWR, May 21, 2010.
  1. KXWR Husqvarna
    The rear brake on this bike doesn't have a lot of power and then it will lock up.The pedal and caliper work fine and no spongy feel. I would like to try different pads and maybe a different rotor if the pads alone don't solve the problem.Has anyone tried a different pad and rotor set?
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    What's on it solid or wave? What are your pads, sintered, mixed?
  3. KXWR Husqvarna
    It has the solid rotor and Brembo pads.Came stock on my bike.
  4. 2stroked Husqvarna
    B.C. Canada
    The stock pads sucked on my bike, try new pads when the stockers wear out.
  5. Anthony_1978 Husqvarna
    Melbourne
    I had the same problem on my WR250 2009mdl:thumbsup:
    the problem turned out the be that the eliptical freeplay adjuster needed adjustment (back it off the pedal) and give the pedal more freeplay. without enough freeplay, my rear rotor got so hot, it turned blue and cooked the brake fluid :doh:
  6. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Mine need constant adjustment. The solid rotors just eat the pads!
    My rear pads are dead and my fronts are still at 60% :excuseme:
    They work good though if you keep them adjusted.
