125-200cc '11 WR150 setting with fmf pipe/ silencer
Discussion in '2 Stroke' started by inklax2, May 14, 2012.
  1. inklax2 Husqvarna
    Norwichtown, CT
    2011 WR150
    Can anyone help me with jetting settings on this bike with the fmf gnarly and pc2 silencer? It has a really bad bog down low and is almost impossible to climb steep hills at a lower rpm. Yesterday in a harescramble i couldn't even let the clutch out without it cutting out. Unfortunately this happened 2 laps in. Now it won't even start. Plug color was a light brown. I am new to having to properly jet my own carb so take it easy on me! It's the mikuni tmx. Thanks, Nick
  2. Vinduro Husqvarna
    Mississippi
    First check your float level. Most come way high. It should be about 8mm above the body just as it touches the needle. Then check the jetting sticky on proper jetting. I would think that a 30 pilot is a good place to start.
