125-200cc 12/48 gearing
Discussion in '2 Stroke' started by troy deck, Apr 21, 2013.
  1. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    anybody else out there running 12/48 on a 144 just bolted it on Friday raced it today got the class win against a field of mostly 250s its all stock but the gearing all i can say is that is one HARD HITTIN,PULLIN LITTLE BASTARD ill tell the truth its the nephews i rode it after the race just to see i'm 6 2 390 yes 390 ridin for 40 years & it pull me AS HARD AS I WANTED a gearing change really seems to be an answer
  2. huskybear Husqvarna
    B.C. Canada
    I am running 13-53 gearing on mine and I like it, my left foot is pretty busy at times but it will climb trees!:cheers:
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    damn 4.076:1 ur shorter than we are but the nephews diggin it yours stock?
  4. huskybear Husqvarna
    B.C. Canada
    No,stock gearing was 13-50. I have a 36mm lectron carb and recently put on a fmf fatty pipe. I ride a lot of steep,tight stuff. I may go a tooth or two less on the rear if the rear sprocket ever wears out(stealth sprocket-lasts forever!) Works for me!:thumbsup:
  5. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    yea i went with an OE 12 & 48 supersprox & RK O-ring and had it all cryroed we'll see how that lasts
    huskybear likes this.
  6. Vinduro Husqvarna
    Mississippi
    13/52 gearing is the way to go on the 150 & 14/52 is best for the 165. 12/48 is exactly the same as 13/52.
  7. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    I have 13-52 on the WB 165 and its all smiles here.
    would consider changing it with the next sprocket set change, but would probably go for a 13-50.
    on the 125 cylinder I did run 12-50
    I would not know how much the lectron would add and if I would need to adapt the gearing for it.
    Robert-Jan
