125-200cc '12 CR125 Engine Speed Increasing
Discussion in '2 Stroke' started by chestnut250, Apr 27, 2015.
  1. chestnut250 Husqvarna
    2013 CR125/144
    2006 CRF250X, 2012 CRF450R
    So this is my first post to this board (which has been unbelievably helpful when I'm seeking information!) and after searching through the forums I haven't seen an answer to previously.
    While on a trail ride this past Sunday my sons CR125 began having an odd issue. After a hill climb we stopped for a moment and his engine began revving to the moon with any throttle input. He shut it down and I went over to check things out. Inspected the throttle tube and cable, no binding, pinching, or stretching. Looked around the carb and nothing was out of the ordinary. Started the bike again and it started normally but then began creeping up in RPM on its own once again. We nursed the bike back to the truck since this signaled the end of our riding day.
    Could this be a clogged or restricted jet causing the issue? This bike is stock other than an FMF spark arrested slip on, which hasn't caused any issue before. Any advice where I should start checking for problems?
    Thanks in advance to anybody willing to post up suggestions as to where to begin looking for the cause of this issue!
    -Dan
  2. Motosportz CH Sponsor
    It could be a bit lean and is running on after getting a little hot on the climb. Or you could have some junk/water in your float bowl getting in the pilot or main and making it lean. Have you ran it since then? When and how often does it do this or only has done it once? Reed cage tight and well sealed? Carb clamps tight?
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    i'll second both of those look closer oh and check the filter screen on the petcock
  4. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Tap on the float bowl when it happens to see if it's sticking closed. Usually it sticks open and gas flows out of the vent tubes... But, your saying it's idling fine, then revs when you roll the throttle, even a small turn?
  5. chestnut250 Husqvarna
    2013 CR125/144
    Thanks for all the quick responses, guys! Motosportz, we haven't ran it since then but after it started doing that on the ride Sunday is continued. Every time you pulled in the clutch the motor would start revving. I will start it again tomorrow and see if it persists. I'll also check the reed cage bolts and intake boot clamps as well as tap the float bowl if it does it. Flyingbob, it doesn't idle fine. When you let off the throttle it just keeps climbing in RPM. Also, when you start it without touching the throttle it would start increasing RPM. I'll report back tomorrow with my findings. Thanks again, everyone!
  6. Bloodline Husqvarna
    WR125
    It's lean, for some reason. air leak (crank seals, intake manifold/reeds) or a fuel issue (float height, clogged vent line(muddy?), clogged jet, debris on needle or slide(yikes)).
    I noticed on my brand new WR125 that the vent lines on the carb were cut square. They should be cut on an angle to prevent mud buildup from blocking flow.
  7. Motosportz CH Sponsor
    Pull the bowl off and see if your pilot jet is laying in the bottom of it.
