125-200cc 12 tooth counter sprocket
Discussion in '2 Stroke' started by ajaxauto, Nov 1, 2010.
  1. ajaxauto Husqvarna
    Want to gear down a CR 125 for the Las Vegas Endurocross on Nov 20th Already run a 52 on the rear and really do not want to go any bigger on the rear .So any one ever use a 12 tooth on the front
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Ajax,
    I have been running one all year. I thought it would wear faster than the 13 but seems about the same.
    Darin
  3. rancher1 Husqvarna
    WA
    Check with kelly, he runs both 12 & 13 and has them on the shelf.
  4. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    I've got a 12 on my TXC 250 but still run a 50 on the rear. I've been told one tooth on the front equals 2 or 3 on the rear so I'd be afraid of running a 12/52 unless you really want to tractor.
  5. ajaxauto Husqvarna
    all we want is a tractor for the endurocross Then it is back to desert racing where 13 52 works great
  6. Kevin_TE250 Husqvarna
    Boise Idaho
    been running 12 / 50 for a year now... works great ! now that I'm getting the 167 on may go to the 13/50
  7. fury1 Husqvarna
    ma.
    id rather run the 12/50 combo,you risk banging sprocket off rocks and tossing the chain with the 52t rear
  8. krieg Husqvarna
    Matthews, NC
    Many in the past
    You should definitely tractor right along with a 12/52! :thumbsup::cheers:
  9. wallybean Mini-Sponsor
    Montana
    John,
    I run a 12x49 combination with the 144 and it works well. 12x52 will probably be ideal for enduroX. What are the dates for the Las Vegas EX?
  10. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Endurocross - youre a brave man - Good luck
