14/48 set up
Discussion in '610/630' started by MotAd, May 5, 2012.
  1. MotAd Husqvarna
    London
    SM701
    2009 Triumph Daytona 675
    anyone tried a 14 tooth on the front with a 48 on the back? about to put new c&s on and i have a new 15 tooth front and 48 rear but wondering whether to go the whole hog and stick a 14 on the front.
    trying to get the bike quite animal but i'm commuting on it so i don't want it to be a stunt machine...
  2. mike54 Husqvarna
    A friend tried it on his - says its way too short. 15/46 works for me
  3. johngil Husqvarna
    Reseda, CA
    Too low in my opinion.
  4. MotAd Husqvarna
    London
    SM701
    possibly. will see how i get on with 3+ on the back at first. if i want more ooomph then should be able to fit a 14 front without having to adjust chain length :)
  5. 1lunger Husqvarna
    Bloomfield CT
    I was looking at the 14/47 setup from Renthal. I'm in the woods more than the road these days. The 14/45 is ok, but I would like to try it.
  6. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    14/47 for me! thinking of 14/49.....:banana:
    1lunger likes this.
  7. 1lunger Husqvarna
    Bloomfield CT
    What's the 14/47 like? Can you still hit 70 mph without ringing its neck?
  8. senorpeligro Husqvarna
    Fremont, CA
    BMW F800GS
    I'm running 14/45 and it's pretty sweet.
  9. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    i dont do alot of highway riding but it still rides comfortably at 100/110kmph. if i was to do a long trip involving big hwy kms i would swap it back to stock but for me its fine.
    1lunger likes this.
  10. KLOC Husqvarna
    Edmonton, Alberta
    15/48 here.
  11. MotAd Husqvarna
    London
    SM701
    got a 48 put on the rear today while getting a rear tyre fitted. stuck with 15 on the front. feels much better but still reckon 14/48 could work! :thumbsup:
  12. MotAd Husqvarna
    London
    SM701
    ok so tried running the 14/48 for a few weeks but didn't really like it. as was said earlier it's too short. it puts the bike in too high revs for the speed it's going meaning that you're outside of the best of the torque range. 15/48 is just about perfect for me i think. as long as i've got the output sprocket on the right way round ;)
  13. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    will a 13t front sprocket fit on a 610 without issues? i am running 14/47 but would like to try 14/49 or 13/47 (pretty similar according to gearing commander). a front sprocket is alot cheaper than a rear for a quick test run....
  14. Sizzler Husqvarna
    Blue Mountains
    CBR600, SZR660, TLM260. DRZ250
    There are downside to going smaller on the front sprocket.
    At 13, it is starting to become a tight turn for the mass of the chain to change direction. This eats power and increases wear.
  15. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    ok, thanks. i might give it a miss then.
    cheers
  16. 1lunger Husqvarna
    Bloomfield CT
    14/46 works a charm! The front lofts effortlessly in 3rd at an point in the rpm range. I can still do highway speed, I just choose not to.
  17. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    interesting. my front certainly doesnt loft effortlessly in 3rd and i run 14/47:confused:. in fact i cant remember the front lofting in 3rd ever??
  18. 1lunger Husqvarna
    Bloomfield CT
    Did you install the JD tuner and open the air box? I'm not sitting on the gas tank when I ask it, but I'm not trying very hard either. I will say that having the suspension set up right helps matters too.
  19. 1lunger Husqvarna
    Bloomfield CT
    I guess I need to get a go pro and prove it.
  20. 1lunger Husqvarna
    Bloomfield CT
    Any chance our ECUs are different? I know they make 3 or 4 different ones for the TE 610
