18" rear wheel
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Poopy, Sep 6, 2009.
  1. Poopy Husqvarna
    Kamloops, BC
    WB165
    What is the most economical means of getting an 18" wheel on my TC250?
    Is there any aftermarket parts? Are hubs all proprietary? Does any other brand fit? Do I have to bend over at a dealer?
    Thanks!
  2. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Did you check out our classifieds or put an ad in there. Maybe some is selling a rim or two.
    Check out EBay. Might be something in there too.
  3. mikenpalsie Husqvarna
    northwestern il.
    you could buy an 18" rim and spokes, re use your hub and brake set up.
  4. Motosportz CH Sponsor
    Bingo. less than $200.
  5. Poopy Husqvarna
    Kamloops, BC
    WB165
    Not bad, not bad..... thanks for the idea...I still would like to have two separate wheels for quick tire changes for different riding.
  6. OM48 Husqvarna
    S.W. Pa.
    Try Fugi Factory. Its a guy in Deleware that has used Husky parts, he fixed me up. Hey Fuji you out there? Maybe try to look for him on TT
  7. priapism Husqvarna
    sherman oaks CA
    What is the advantage of an 18 over a 19? My KTM has an 18 but all my buds have 19s.
  8. Poopy Husqvarna
    Kamloops, BC
    WB165
    I want to try a trials tire is my main motivation, they only come in 18".
  9. mikenpalsie Husqvarna
    northwestern il.
    Priapism,
    i belive the reason for an 18" wheel is so you can run a taller tire and reduce the chance of getting pinch flats. if you dont ride in a rocky/ wooded area, you could stay with a 19" wheel.
