1st Valve Check at 3400 Miles
Discussion in 'General (Main)' started by proeasy, Jul 24, 2010.
  1. proeasy Husqvarna
    SE Michigan
    TE-630, TE-510
    R1100 RT, XR-400R
    Ok I know I should check the valves more often but the miles came quite fast on my 08 TE-510
    Here is what I measured, however smallest feeler gauge i have is is .008.
    Ex. 1 .008, 010 does not fit
    Ex. 2 .008 does not fit so, less than .008
    Spec is .006-.008
    Int. 1 .008 does not fit i.e. less than .008
    Int. 2 .008 fits but is loose, .10 does not fit
    Spec is .004-.006
    As I am new to this, exhaust seems ok, but intake seems to be a larger gap. Should I park the bike till I get them adjusted correctly
    Appreciate comments
    Paul
  2. Coffee CH Owner
    You should check them more often :)
    Park it? I wouldn't, but soon adjust at least intake #2.
    Mine were significantly off from the factory, apparently you were more lucky.
  3. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Some bikes just seem to stay close.
  4. JRD Husqvarna
    Sydney
    I would get some new feeler gauges if the thinnest you have is .008'
    You really need to get an accurate reading.
  5. rancher1 Husqvarna
    WA
    What he said !!! :thumbsup:
