2 rim locks on rear?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Biggziff, Jul 3, 2012.
  1. Biggziff Husqvarna
    Upstate, NY
    TE510
    KTM 1190R, 500 EXC, 1970 Suzuki T250
    I was cleaning my chain and noticed that the rear tire has spun a little and the valve stem is tweaked just a little bit. I'm running 13 pounds in the rear (Stock DOT Michelin knobby on TE510). Do you guys just default to 2 rim locks to prevent this?
    thanks
  2. huskybear Husqvarna
    B.C. Canada
    All the big-bores that I have owned had 2 rim-locks with no issues:thumbsup:
  3. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I just have one on my 630; haven't seen the tire spin at all since I put it on.
    I believe some people run 2 to make balancing easier.
  4. Motosportz CH Sponsor
    Yes, can do. I have never needed to but it does work and if you place the other one directly across form the first one you get a better balanced wheel.
  5. Ruffus Husqvarna
    I run dual rim locks front & rear. Eliminated out of balance vibration @ highway speeds & piece of mind if there's ever a blowout. Also great for getting back to where ever if you have to ride a flat out of a trail, keeps the tire on. And of course less chance of spinning a tire on the rim & ripping off the valve stem.
    Does make mounting a new tire a wee bit more challenging. :censored: :D
  6. Ruffus Husqvarna
    P.S. I used the valve stem hole as my second rim lock location as it was directly across the factory one & just drilled a new valve stem hole center of the 2 rim locks.
  7. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Are you sure your rimlock was tight enough? I have heard 9ft lbs and that is actually pretty tight when you feel it with a box wrench.
  8. Biggziff Husqvarna
    Upstate, NY
    TE510
    I'm going to check it now. My WR450F had 2 on the rear and never slipped. The PO of this bike did install 4mm tubes so maybe he didn't tighten things down. If I decide to run 2 would it take a 2.15 or 2.75 lock?
    thanks
  9. ghte Husqvarna
    Bright, Victoria Australia
    Should not need an additional rim lock from a slippage perspective but are very good for balancing and runniong on flats.
  10. Biggziff Husqvarna
    Upstate, NY
    TE510
    Well, mine was very tight yet the tire had spun!
  11. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I concur, Odd yours spun if installed properly (maybe its just a freak occurrence)- maybe the previous installer used a weird tire installing slime that did not evaporate and added slip. You can use 2 as stated. I use one rim lock, and I run 8-9 lbs on my rear tire, and 9-10lbs on the front. I have never spun mine and FWIW or a laugh, my knobbies are very worn and the car broke down so I actually used it to go to work, and once I got home, I did an on the pegs- 25ft burnout in my paved driveway- didn't spin on my rim. Time to change tires before I turn into a SM hooligan and show the world my newly obtained skill.:thumbsup: I was just doing what Shane Watts (instructional video) told me to do officer- just trying to improve my counter steering skills. :lol:
    huskybear likes this.
  12. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    I run two front, two rear, for those days when I have a flat. Makes riding it out much easier...
