125-200cc 2 stroke timing
Discussion in '2 Stroke' started by mark1, Apr 30, 2015.
  1. mark1 Guest
    hi ive just had a engine rebuild on my wre 125 and have vibration the shop that done it said it was hard to get balance wait timeing right .so am taking of the clutch case ive got a Manuel but don't quite see how to time it up manuel diagrams are confusing do I just line up all the dots punch marks?? any help would be appreciated
  2. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    you had an engine rebuild, do you mean just the top half of the engine, the piston and ring being replaced, or the bottom end too, ie the crank and main bearings? Vibration shouldn't be noticeable on a new engine, where's it coming from roughly? The clutch on a 2 stroke is nothing to do with the ''timing'', it comes from an ignition coil down into the spark plug, no valves to set up or timing to set up, are you sure you're not confusing it with a 4 stroke? They're timed by valves and a camshaft cam chain which runs down the side of the engine, opposite side to the clutch
    mark1 likes this.
  3. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    mark1 likes this.
  4. mark1 Guest
    Hole engine rebuild new crank etc and ther is timing in engine. The ballance weight times against clutch and other cogs and yes its 2t not 4
  5. mark1 Guest
    thanks that's just what I need to correct what this so called mechanic has fucked up ,just cheaked and timing was 2 teeth out ..some one else replied telling me that 2t don't have timing (balance weight) and that it nothing to do with the clutch lol .thanks again m8 my bike is ok now
  6. mark1 Guest
    thanks
    Petar and juicypips like this.
