310cc big bores
Discussion in '4 Stroke' started by thenash79, Apr 20, 2010.
  1. thenash79 Husqvarna
    nj
    Hello planning on doing athena 310kit on my 08 te250. I read some of you were having problems with the neutral light after bbk. Is this with stock 08 te250 ecu an athena's addon module ,or stock 09 310 ecu , or with stock 08 te250 ecu with powercommander?
    Also is there any downside to the 310kit besides less gas milage and may run a little hotter? I have had many buddies do big bores on other bikes and it ends up killing drivability (too radical) and some eat starters. It looks like kit will lower compression so hopefully these issues will be ok.Thanks for feedback!!
  2. Motosportz CH Sponsor
    Does not get worse mileage nor have I noticed any issues with overheating. It is a very good kit, adds power everywhere and seems reliable as stock.
  3. HomeFinance Husqvarna
    Ditto. Best mod I have ever done to any bike. :thumbsup:
  4. bigcahunak Husqvarna
    Israel
    The light issue is only when you get the original husky kit. The reason is because the kit is actually 09 parts with an 09 ECU which works with the 09 odometer/panel unit, which is different than the 08 unit. Other than that, your 08 250 becomes an 09 310, which is what I did to mine when I had the 08.
