310R. 2013
Discussion in '4 Stroke' started by NYCMX, Aug 1, 2018.
  1. NYCMX Husqvarna
    Spring Hill Florida
    13 TE310R,13 Strada,
    1977 Rm125,78 Rm125, 80 RM125...KTM
    Just wanted to let you know my bike has been great over the last year. IMG_20180801_222349.jpg
    Oldscool likes this.
  2. NYCMX Husqvarna
    Spring Hill Florida
    SO it's a 2013 Te310R that I had quite a few teething issues with in the past. But sometime last year after deleting the starter and some other mods it has been running perfect. It starts easy with the kicker and run's better then ever. I have been riding it usually about 3 times a week in the hot Florida sun in the deep sand. The bike is fast and reliable in the woods. Maybe a little too fast.
    Anyway just wanted to say thanks to all the Cafe members who helped me out in the past (Trench etc.) and I have the starter if anyone needs it, I think it's still good.
    It's going to be 98 degrees tomorrow and i'm all prepped for a day in the swamps.
    Oldscool and Trenchcoat85 like this.
  3. NYCMX Husqvarna
    Spring Hill Florida
  4. R_Little Husqvarna
    NJ
    My 2010 2010 TE250 was the same way. One of the 1st U.S, market x-lites. Lots of issues out of the box, but it's been running great for 6 years since sorting it.
    I have the starter still on the bike but use it only for trail stall restarts. I kick it mostly. From the top smooth and it lights 1-2 kicks all day long.
    I'd be happy to buy the starter from you.
    PM me a price.
    I have a question about the heat.
    if your bike is a red head, do you ever boil gas in the tank?
    There is not a lot of clearance between the tank and valve cover.
  5. NYCMX Husqvarna
    Spring Hill Florida
    I never had overheating problems, The fan runs when it gets hot. I did have to shim the tank in 2013 because a rad hose was rubbing, been fine since.
  6. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    No issues with my 2013 other than the starter which was bad on the showroom floor. Fixed, and good to go since then. I have a large tank on the way and intend to use the 310 for multi-day trips with light soft luggage. Great bike!
    NYCMX likes this.
  7. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Have you guys ever weighed your bike? Just curious. Suppose I should search!
  8. NYCMX Husqvarna
    Spring Hill Florida
    I never did weight the bike, but it is a heavy 4s. My wild guess is around 245lbs with all the stuff I deleted. 29594861_10157141295424688_4384777231499860824_n.jpg
    Trenchcoat85 likes this.
  9. NYCMX Husqvarna
    Spring Hill Florida
    headlight has to go. Anybody know the part # for a front plate?
  10. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    part #80C0 A4216 for the 2009-2014 TC (250,450,510), CR (125,150) TXC (250, 310) and SMR models. Should even go earlier into the blue/yellow era
    Looks like you'll pay around $38 from husky, so go for the polisport, ufo, or acerbis aftermarket plate instead (one of 'em is usually the OEM anyways) Don't forget the cable holder.
    edit: here, get this white one on ebay for $22.36; should fit everything Italian from '05-'14
    https://www.ebay.com/itm/Polisport-8658200002-Front-Number-Plate-White/332555048660
  11. NYCMX Husqvarna
    Spring Hill Florida
  12. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    Whoops- wrong plate. Was that the number I gave you? Looks okay anyhow.
    NYCMX likes this.
  13. NYCMX Husqvarna
    Spring Hill Florida
    Thats a "take-Off" from the GPX (the greenish bike above). White plate ...and it fit well, the front fender on the other hand was a no go.
