4 Stroke Lectron - 04 TE 250
Discussion in 'EFI/carb' started by dukepilot, Sep 11, 2013.
  1. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    450 SMR, TE250, CR125, SM610
    Duc, Buell, Honda
    Replacing the stock Mikuni TMR 36 pumper carb on this bike with a 36mm Lectron with remote choke setup, adjustable power jet and air bleed adjustment screw.
    The carb arrived from Lectron setup to Motosportz specs, including a nice Motion Pro Vortex throttle and cable to replace the stock push/pull cable setup.
    Install was very easy, the carb slipped in and the cable and throttle were fitted without any problems.
    I'll have more info on how it runs with this carb later today.
    Left side view
    Right side view
    Throttle
    supervision likes this.
  2. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    The bike fired up and settled into a fast idle. A couple of quick throttle snaps resulted in immediate throttle response. Exhaust smells a bit rich. Going to try 1/4 turn leaner on the rod, then fine tune with air bleed screw and adjust idle speed. The tank needs to be removed or lifted to access idle adjustment, power jet and air bleed screws.
  3. Motosportz CH Sponsor
    thanks for the info. Look forward to your review. Are you running the stock tank or oversized?
    - I was really surprised at the snappy throttle on the 610 install as well beings it has no accelerator pump. The cool thing is it goes from a super complicated carb to a super simple one and works great.
    Oh, I know it is not EZ with a 4 stroke setup but make sure to play with the adjustable power jet screw too (upper mid and top end power). Makes a noticeable difference.
  4. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    Thank you for setting up this carb to fit my bike so easily! I'm using the stock fuel tank. The fuel inlet on the carb is quite a bit higher than the fuel petcock outlet. Still flows gas on reserve while on the bike stand, shouldn't be a problem.
    I did turn the rod out 1/2 turn. It still smells rich but idle is a bit steadier at around 1500 rpm. Might have to go a bit leaner but I'll ride it first before making any further changes. Right now it starts easily with a crack of the throttle and idles ok.
  5. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    Might have to get one of these for my 450 to replace the TMR on that bike!
    I love the simplicity, the single throttle cable and the remote choke.
    Motosportz likes this.
  6. Motosportz CH Sponsor
    I have found they are nearly impervious to water or dirt too. Love the simplicity and functionality of there things. I wish I had my hard starting at times 2010 TC250 back to give one a shot on. Bet it would be seriously awesome on that bike.
  7. Motosportz CH Sponsor
    Is the carb slightly short for your install? Seems the front is not in all the way?
  8. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    I believe its all the way in (checked it twice) but I will check it again.
    The bike blows a noticeable amount of black smoke when snapping the throttle open from idle. Runs ok though.
  9. Motosportz CH Sponsor
    That can be dialed out some but is going to be the case with these carbs. The 4 strokes have a lot of draw and the rod is very sensitive to this and why no accelerator pump is needed. The down side is a slight rich condition when you snap the throttle and it causes instant draw of fuel sitting right at the orifice waiting to go.
  10. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    That's probably why I'm smelling excess fuel in my exhaust. So long as it runs good, a little smoke is no big deal!
  11. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I hope you get it sorted out.
    TROFFER88 likes this.
  12. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    Took the bike out for a short ride today. No bogging and crisp throttle response. Throttle response is much improved over the stock Mikuni TMR. This was the easiest carb conversion ever!
  13. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Great to hear.:thumbsup:
    Were you able to give her some good WFO through the gears to see if the idle is stable?
  14. Darkside Husqvarna
    SF Bay Area
    none left
    beta, ktm, aprilia
    Are these the same carbs as on the 2T's ?
  15. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    Idle is stable after a few WOT runs. This bike has the original version Rekluse Z-Start clutch so consistent idle speed is important. I'm going to lean out the rod a little more and make some adjustments to the PJ. I think I have a pretty good staring point to evaluate further changes.
    Motosportz and 454x like this.
  16. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    Duc, Buell, Honda
    Same basic carb body but with a few changes. The metering rod is different/longer and the 4T version spec'd by Motorsportz has the remote choke and an air bleed screw to adjust idle/off idle fueling.
  17. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Good looking bike and thanks for the thread.
  18. Motosportz CH Sponsor
    Awesome!!! :cheers: Wonder if your MPG will go up as well. Look forward to your reports.
  19. Motosportz CH Sponsor
    Yes and no. Same basic carb but reconfigured for these 4 strokes and the specific bike. They are machined to fit perfect, have an added air bleed circuit to adjust the bottom end EZer which is the tough part on a 4 stroke with a Lectron, different rod, some other small changes. Basically a highly modified 2 stroke carb. No pumper and still quick instantaneous throttle response. From the most complex carb to the simplest and still runs better. Win / win. Nice.
  20. Motosportz CH Sponsor
    We had three husky 125s with 165 kits and lectron this weekend, all ran fantastic 3200-7200 feet with zero adjusting.
