125-200cc 40:1? 32:1? what ratio are you running?
Discussion in '2 Stroke' started by HUNhusky, Feb 10, 2015.
  1. HUNhusky Husqvarna
    Long Island New York
    2007 te450
    kx100, sv650, crf80f
    recently purchased a 2006 cr125, previous owner said he ran 36:1. just looking around to see what kind of oil and what kind of spark plugs you guys are running in your bikes?
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    50:1 synthetic
    new bikes show 60:1
    when i was sponsoring a bike we were 100:1 synthetic, no wear issues
  3. Cookies Husqvarna
    Canyon Lake, California
    2009 TXC450
    Had: 78 390 Auto, 83 cr250 84 cr250
    most people use too much oil, i.e. 32:1. Remember the more oil you use, the less gasoline will be present, thus leaning out the mixture, sure everything is lubed well, but the engine is still lean. With todays Synthetic oils, 50:1 is not uncommon.
  4. HUNhusky Husqvarna
    2007 te450
    what brand oil are you guys using?
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i use klotz super techniplate castor/syn blend @ 40:1. hardly any smoke, no spooge. my 88 250 has run it almost its whole life. still running great on stock piston.
  6. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    40:1 with Maxima K2 here.
    HUNhusky likes this.
  7. justintendo klotz super techniplate junkie
    your engine will also not be "lean" running 32:1....jet accordingly.
  8. Big Timmy Husqvarna
    (South Eastern) AZ.
    Take also into consideration excessive amounts of oil can actually cause the engine to work harder by increasing friction and parasitic drag alone.
    To much 2 stroke oil added to the gasoline can also have an effect on reducing the specific octane rating of the gasoline used as well by simple mathematical dilution.
    Gotta love the smell of any castor based oil out on the trails as well. Castor based oils once introduced into the internals of any fresh 2 stroke engine, once run at operating temperature will leave a beneficial micro thin layer of protection unlike anything else. That protective layer will remain on the surface nearly for ever unless removed with strong chemical cleaners during teardown. Even gasoline will hardly remove this film or layer.
    Even the lower content of Castor oil by percentage in 2 stroke Synthetic blends that are now available will leave an oil film on all the metal surfaces that do not have direct wear against other components. Like the bottom sides of the sleeve or bore, the rod, flywheels, etc. This will protect the internals from oxidation or corrosion during long periods of storage.
    Full synthetic 2 Stroke oils just don't have the ability to do this as well in my opinion.
  9. HUNhusky Husqvarna
    2007 te450
    what kind of spark plugs you guys running? ive read these husky's are pretty specific in what they need, a spark plug with a resistor ( i think its called ) big timmy.what kind of oil do you use? brand wise
  10. dirt-dude Husqvarna
    Pa.
    Maxima K2 @44:1 NGK BR8ES
  11. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    Amsoil dominator @50:1 NGK BR8ES
  12. justintendo klotz super techniplate junkie
  13. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
  14. ajaxauto Husqvarna
    OMG Here we go again but since you asked My 2006 CR 125 which is still on the original bore since new and had won the following
    2 National # 1 plates in the AMA National Hare and hounds 1 in the 125 expert class and 1 on the over 50 open expert class
    Won a few Dist 37 Desert races
    Ran as high as 6th overall finish at a Desert race out of 300 plus entered
    Preran King of the Moto 3 years in a row
    Has a ton of miles by 3 different expert riders ect ect
    So here is what has worked for me Stock jetting from the factory never change from sea level to 8,000 feet
    BR9EG Uriduim Plug
    mixed lucas semi synthetic oil about 35 to 1
    110 leaded race gas
    This has worked for me like I said still on the original bore My 2008 CR 125 which is now a 165 gets the same stuff NEVER lost or hurt a motor in either bike
    I talked to Walt today as my son wants to make it a 165 and do KOM next year Poor old bike keeps ticking
    PS lower end is also all original except one crank kit
    HUNhusky and Big Timmy like this.
  15. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Just remember the golden rule. You bought the bike running and jetted for 36:1. Start there and see how it runs, what the plug looks like etc.
    Motosportz and HUNhusky like this.
  16. Big Timmy Husqvarna
    (South Eastern) AZ.
    Been running old school "Blendzall" green label #460 for 40+ years in my vintage Maico's. I buy it by the case.
    Have tried a few bottles of the "Klotz BeNol" also but don't look for it or see it very often. Since I get the Blendzall just shipped to my door.
    If I store pre-mixed fuel over the winter here which I normally won't do, I'll keep a bottle of the #490 booster additive that keeps the castor from separating if it sits for a long time. Only a few ounces is needed to do this. Shaking the bike around good before riding probably does the same thing. I am one of those guys who leans the bike way over to dump fuel from the carbs overflow tubes all over the floor of my shop or ground when the bike is cold before kicking it anyway. Saves my bad knees a bit and it lights right up.
    They now have a #465 Gold label that has the booster already in it but I just mix the two (#460-#490) myself. Its what I've used for years and don't have any reason to change.
    I've ran full synthetics before just don't care for them. Except maybe in my 3 chainsaws. Husqvarna, Stihl and my cheapy loaner Poulan, the one and only one that ever gets loaned out. :D
  17. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    This is an article I remember reading back in the day, it has some interesting points.
    I personally use Amsoil interceptor at 32:1 on my bikes.
    Later,
    Big Timmy, Motosportz and HUNhusky like this.
  18. 2premo Husqvarna
    Northern NV
    lets do some simple math, parts of gas to parts of oil
    36:1 = 2.77777%
    40:1 = 2.5%
    50:1 = 2%
    unless you are tuned to the n'th degree on a flat area such as a competition course and i don't mean enduro stuff
    realistically unless you are tuning as lean as you dare for the last 2% of power available then less than 1% won't change much
    spooge usually comes from poor ignition as in not burning clean, gross over jetting, bad spark plug, low compression, timing off
    you probably get where i am going with this
    if you don't feel comfortable with 50:1 don't lose too much sleep
    don't worry about rejecting when you change the ratio either there is no jet that will compensate 1% available from anyone
    if you plan to run a lot of elevation differences typically i jet for the lower elevation
    FYI most of my riding is 3000' of elevation difference
    the quality of the gas you run is more important, i run Chevron premium as it is the most consistent, the manufacturers of cars use it for emission testing
    a lot of members run fuel that is for competition with no ethanol (a big deal) i am at high altitude so don't have the issues that would affect me there 5000-8500'
    enjoy the ride!
    Big Timmy and HUNhusky like this.
  19. HUNhusky Husqvarna
    2007 te450
    2premo i see what your saying, the minute differences between mixes isn't going to even be noticeable by me, as long as the bike runs fine theres not much to scratch my head at. as far as the gasoline used ( i live in the USA ) what octane do you guys use? pump gas the highest we can get is 97, but I'm sure i can find some race gas around somewhere.. with a 36:1 ratio, what kind octane gas are most of you running? thanks for all the help guys
  20. 2premo Husqvarna
    Northern NV
    interesting read
    i sponsored a friend of mines son on a Suzuki 60 in the day, he won almost every event he entered, so we built him a modified 60 that ran higher RPM, again won almost every event, we were teched after pretty much every race for a year and had the top end off regular no wear, 100:1
    he was the US mini champ for quite a number of years, i quit sponsoring him when he got a factory ride with Kawasaki
    Eric of Eric's Pasadena who won an ISDE gold said there was no reason to run extra oil, he did his dyne work at 150:1 with no visible wear
    after long discussions he got me to go 50:1 and said i was chicken, the new as in KTM and Husqvarna recommend 60:1 right in the owners manual
    all my buds that ride these have had no problems all these years
