40mm fork seals?
Discussion in 'Vintage/Left Kickers' started by Dwarf66, Nov 1, 2014.
  1. Dwarf66 Husqvarna
    CT
    79 250OR 84 250WR 87 510 TE
    78.5 RM250C-2 82 PE175Z
    Hi where to get the right ones to fit 82 WR and oil level and what weight?
    Thanks
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    http://www.cafehusky.com/threads/1-of-5.35165/page-13
    15w oil to start out with at 430cc.
    Tear your forks apart and clean all inside well. Check your top out plastic washers to see if they are all mangled, broke, etc.... You can get those from Phil at Husqvarna-parts.com for 40mm forks.
    Also, put new air valves in top.
    Seal size is 40mm ID x 52 OD x 7,8,9mm thick.
  3. Dwarf66 Husqvarna
    CT
    Thanks
  4. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Or you can use Kawasaki 80's 1000 eliminator street bike fork seals, i've used them for years.
    Husky John
  5. Kartwheel68 Husqvarna
    Newnan, Georgia
    I use 1984-85 Honda XL350R fork seals which are 39x52x11, one per leg. They are hard to get the tube in the seal because they are 1mm smaller ID than the stock ones, but they dont leak.
  6. Bigbill Husqvarna
    '83 250wr
    0 right now
    Don't forget to pre lube any seal during the assembly.
    Even on the rear wheel seals and engine crank seals pre lube them.
    Sorry for the refresher on pre lubing seals. Sometimes we find ourselves in a rush. I was when I was younger now I'm old and slow but I'm fast on wicking it.
  7. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    4 fork seals (2x2)
    40 mm x 52 mm x 8/10.5 mm !:thumbsup:
    oïl DEXTRON 430 cc 10 or 15 W !
  8. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    Phil at Husqvarnaparts has the best leakproof seals ive ever used, 3 years on the 400 and just the tiniest hint of a weep after a long ride so :thumbsup: from me.
  9. Bigbill Husqvarna
    '83 250wr
    0 right now
    Do you guys put a thin layer of silicone inside the fork tube and the outside diameter of the seal during the installation? I pre lube the tube and seal contact area so it's not dry during the installation.
    I purchased three pairs of the 500cc single shock front forks thinking the front fork springs and valving would be heavier duty for the bigger engine. Now I need to figure out what kind of oil brand wise and what weight oil. I need an oil weight in between so my son can ride it and I can ride it. I just putt. Probably the stock weight oil might be ok. I'm not sure what the stock weight oil would be?
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Ask Drew at Wer. He pretty good with those forks and rear shocks.
  11. Kartwheel68 Husqvarna
    Newnan, Georgia
  12. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    atf seems to work well. comes out pretty clean after some hours as well. it would be a good starting point anyway.
  13. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    ATF is a bout7.5 wt.
    I would go with straight 10 wt and see how you go. if its a little fast on the rebound for you Bill, go up to 12.5 by blending a 10 and a 15.
    im 80Kg, and 10 wt in the 400 seems pretty good.
