40mm xc/wr/cr forks
Discussion in 'Vintage/Left Kickers' started by disonny, May 18, 2021.
  1. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    What is the difference between XC/WR/CR 40mm forks on 82/83 bikes? Is it just damper rods or totally different forks? I want to put a 40mm WR fork on my 78 chassis.
    Thanks
  2. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    The length of the dampening rods is the difference. The exception is the 84 WR lower legs have less over hang past the axle but still used the same WR dampening rod length as the 82-83 wr's.
    Marty
  3. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    Thanks Marty
  4. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Really doesn't matter, on whether you use CR/XC/Wr, because the forks are way longer, then you'll
    need. I put a set of 1979 WR forks on my 76 360CR (78 125CR frame) & as you can see there
    way too long.
