50mm Zoke fork springs?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Treesmacker, Mar 15, 2013.
  1. Treesmacker Husqvarna
    2010 CR150 "Woods set-up"
    YZ125
    Are the springs for the 50mm closed chamber forks the same as the 45mm & 48mm???
    My son has a 2010 CR150 w/50mm on it.
  2. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I don't think they are. You can check part numbers on the Halls Off Road website. Under Husky parts you can look any factory part up.
  3. Xcuvator Husqvarna
    Scholls Oregon
    yes
    The 45 and 50 springs have different diameters.
  4. Treesmacker Husqvarna
    YZ125
    That's what I figured :(
  5. Treesmacker Husqvarna
    YZ125
    Anyone aware of a spring chart with rider weights for the 50mm closed chamber forks?
  6. Xcuvator Husqvarna
    Scholls Oregon
    yes
    You can enter your personal data into Race Techs spring calculator.
    www.racetech.com
  7. Treesmacker Husqvarna
    YZ125
    For the CR125 the weight do not come up and it said to call for spring weights.
    Another problem is this bikes forks were swapped form the KYB to Zoke 50mm twin chambers by the previous owner.
  8. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Maybe try 09 CR/ WR125 because they came with TC Zokes:excuseme:
  9. Xcuvator Husqvarna
    Scholls Oregon
    yes
    erigre likes this.
  10. Flying-W Husqvarna
    wr125
    I just went through what you are going through. The TXC250 uses the Zokes 50mm. Select that as the bike and then you will get part numbers for the springs. The series is 4447XX where XX is the spring rating.
    I bought springs and gold valves (#2606) to put in to replace the stock springs.
  11. Treesmacker Husqvarna
    YZ125
    Thanks! Flying-W
  12. Flying-W Husqvarna
    wr125
    You bet.
    Kent
