630 Water Pump re-seal-Details & pics.
Discussion in '610/630' started by shoolsema, Nov 26, 2011.
  1. tspoon Husqvarna
    Penticton BC
    TE 630
    XR 400
    CRAP, my waterpump is dripping oil. I got my 630 in June of 2010. Purchased from Rocher in Ontario and shipped to Edmonton. I am now living in Penticton B.C. , Scott shipped me the seal and two "o" rings in a bag and I had considered doing the work myself as I thought it would not be too difficult to do, but after following this thread I am considering having it done at a dealer as I am wondering about the shaft being grooved and needing to be replaced as well. Recently spoke to Scott and apparently my replacement clutch shaft is in the mail as well. I am not sure where to go with this, any suggestions ?
  2. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    When you say dripping oil, is it a light film around the water pump housing? If it is it may just need a simple blue loctite fix. Pull the 3 bolts one at a time, give the threads some blue loctite and put them back on at 70 inch pounds. This has worked for me.
  3. tspoon Husqvarna
    Penticton BC
    TE 630
    XR 400
    Thanks XL it is indeed just a film from day to day, but if sitting for a couple of weeks it does drip onto the floor. I will try your method first.
  4. ray_ray Mini-Sponsor
    The Philippines
    Someone please correct me here if I'm wrong but I think the bolts in question extend into the engine case and oil seeps back out via the bolt threads ...
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Truth. Mine oozes just a hair, but not enough that I worry about it. I'm pretty sure it's seepage around the bolt threads. If anything, I'd try to loctite approach.
  6. Drock Husqvarna
    The exact same thing happened to mine. I started by just ordering seals but now have a new impeller shaft and bearings on the way. Looks like the problem goes hand in hand with the "gunk in coolant" issue which ultimately gunks up the water pump.
  7. mekanik Husqvarna
    Kootenays, Canada
    Lots of white sediment junk in my coolant when I did my valve check etc. , still trying to decide on replacement coolant.
  8. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    For what it's worth, and I've mentioned it before, because I could not determine what kind of coolant was put in at the factory, I drained, flushed and refilled with Yamaha engine coolant. No problems to date.
  9. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    I run Peak 50/50 pre mixed coolant in all the bikes. Never a problem with Peak. Back in the day one of the Pro Circuit race teams sponser's was Peak coolant. It was good enough for the fast guys, it is good enough for me.
  10. mekanik Husqvarna
    Kootenays, Canada
    Yeah, I'd like to try the XL coolant the Zip-Ty boys are using but sometimes being a Canadian customer makes things difficult!
  11. Kenneth Webb Livin' It Up!
    Tucson AZ
    Oh yeah, that white gunk. I found it around the radiator filler cap on my 630 when it was brand new! Well, just a few miles on it. That's why I did the flush and coolant change. Never had that problem since, and I hope that it all got flushed away. I wonder what in heck they put in there at the factory?
  12. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    A lot of car manufacturers put a rad sealant in the coolant to reduce embarrasing coolant leaks on new engines. I am a fan of the blue honda Type II car coolant and use it in all my bikes. Changing the husky this weekend. Cam.
  13. tspoon Husqvarna
    Penticton BC
    TE 630
    XR 400
    Gunk in coolant and oil weeping from waterpump problem has been solved. As XLEnduroMan suggested thread sealer on the waterpump bolts is the cure !
  14. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I put some blue loctite on my water pump bolts when I swapped out the cam chain. Haven't seen any seepage since.
